Hal to Registers. Come in, Registers. Over.
27 Sep 2023 20:38 #281739 by endian
Replied by endian on topic Hal to Registers. Come in, Registers. Over.
Hello,
Yes, there is running stuff from Sockheaven but be very carefully... there is config for AKD2G - which is gantry hardware...
Try :
1) put your DC config at the end of the configuration
<syncManager idx="0" dir="out"> </syncManager>
<syncManager idx="1" dir="in"> </syncManager>
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="TxControlWord" halType="u32"> </pdoEntry>
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="TxPositionCommand" halType="u32"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1a00">
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="RxStatusWord" halType="u32"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="RxPositionFeedback" halType="float"/>
</pdo>
</syncManager>
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
</slave>
</master>
</masters>
2) configPdos="true" have to he true because you are something setuping
3) setup SDOs have to be at the beginning before definition of cyclic communicaiton objects
<!--  Set OpMode to Cyclic Synchronous Position  -->
<sdoConfig idx="6060" subIdx="00">
<sdoDataRaw data="08"/>
</sdoConfig>
<!--  Set Cycle Time  -->
<sdoConfig idx="60C2" subIdx="01">
<sdoDataRaw data="01"/>
</sdoConfig>
<!--  Set Cycle exp  -->
<sdoConfig idx="60C2" subIdx="02">
<sdoDataRaw data="FD"/>
</sdoConfig>
4) DC config should looks like this
<!-- <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/> -->
and value of  assignActivate="" should be greater by greating number of active cyclic PDOs ... I do not know if I am right but this parameter is like time window for communication slave in DC synchronized on the fly train ... I am with my old stuff running with 7 in and 4 out cyclic PDOs at assignActivate="660"
from my point of view your basic .xml file should looks like
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<slave idx="0" type="generic" vid="0000006A" pid="00414b44" configPdos="true">
<!--  Clear SM PDOs  -->
<sdoConfig idx="1C12" subIdx="00">
<sdoDataRaw data="00"/>
</sdoConfig>
<sdoConfig idx="1C13" subIdx="00">
</sdoConfig>
<!--  Clear RX PDO1  -->
<sdoConfig idx="1A00" subIdx="00">
</sdoConfig>
<!--  Map status word to RX-PDO1  -->
<!--   0x6041 0010  -->
<sdoConfig idx="1A00" subIdx="01">
<sdoDataRaw data="10 00 41 60"/>
</sdoConfig>
<!--  Map position feedback to RX-PDO1  -->
<!--  0x6064 0020  -->
<sdoConfig idx="1A00" subIdx="02">
<sdoDataRaw data="20 00 64 60"/>
</sdoConfig>
<!--  Set RX-PDO1 count to 2  -->
<sdoDataRaw data="02"/>
</sdoConfig>
<!--  Clear RX-PDO2  -->
<sdoConfig idx="1A01" subIdx="00">
</sdoConfig>
<!--  Clear RX-PDO3  -->
<sdoConfig idx="1A02" subIdx="00">
</sdoConfig>
<!--  Clear RX-PDO4  -->
<sdoConfig idx="1A03" subIdx="00">
</sdoConfig>
<!--  Clear TX-PDO1  -->
<sdoConfig idx="1600" subIdx="00">
</sdoConfig>
<!--  Map control word to TX-PDO1  -->
<!--  0x6040 0010  -->
<sdoConfig idx="1600" subIdx="01">
<sdoDataRaw data="10 00 40 60"/>
</sdoConfig>
<!--  Map position command to TX-PDO1  -->
<!--  0x607A 0020  -->
<sdoConfig idx="1600" subIdx="02">
<sdoDataRaw data="20 00 7A 60"/>
</sdoConfig>
<!--  Set TX-PDO1 count to 2  -->
</sdoConfig>
<!--  Clear TX-PDO2  -->
<sdoConfig idx="1601" subIdx="00">
</sdoConfig>
<!--  Clear TX-PDO3  -->
<sdoConfig idx="1602" subIdx="00">
</sdoConfig>
<!--  Clear TX-PDO4  -->
<sdoConfig idx="1603" subIdx="00">
</sdoConfig>
<!--  Download PDO 0x1C12:01 index  -->
<!--  0x1600  -->
<sdoConfig idx="1C12" subIdx="01">
<sdoDataRaw data="00 16"/>
</sdoConfig>
<!--  Download PDO 0x1C12 count  -->
</sdoConfig>
<!--  Download PDO 0x1C13:01 index  -->
<!--  0x1A00  -->
<sdoConfig idx="1C13" subIdx="01">
<sdoDataRaw data="00 1A"/>
</sdoConfig>
<!--  Download PDO 0x1C13 count  -->
</sdoConfig>
</sdoConfig>
</sdoConfig>
</sdoConfig>
<pdo idx="1600">
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="TxPositionCommand" halType="s32" />
</pdo>
</syncManager>
<pdo idx="1A00">
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="RxPositionFeedback" halType="s32"/>
</pdo>
</syncManager>
</slave>
</master>
</masters>
I am glad to hear something was helpful... try to learn on someones fails no on your owns
The following user(s) said Thank You: rwistort
Time to create page: 0.809 seconds
