- Thank you received: 9
Servo drive config and first movement
2 years 10 months ago #287883
by TimP
Replied by TimP on topic Servo drive config and first movement
there is some movement but really minor, there is no brake, and yes i can turn it by hand
Also have noticed that before failing i'm able to move it a bit, it looks like this;
I can tap on jog + and on halscope ferror is returning to zero after some movement and shaft is also has some rotation. I can do it 4 times and than ferror doesn't return to zero as fast as before, but really slowly and than driver trips into an error with high sound noice. After re-enabling it again if i tap again on + if fails immediately, but it can be moved in opposite direction again 4 times without an error.
2 years 10 months ago #287884
Replied by tommylight on topic Servo drive config and first movement
From your explanation, VFD is not set properly or something is wrong with it, but first check if all 3 wires from VFD to motor are connected properly.
In general, never try to run a VFD/spindle form software before making sure it is working properly on its own, not wired to any control. Use the buttons on the VFD, read the manual, set the setting as needed, and only after this working properly you can wire it to controls and continue tuning.
Spindle not spinning and heating is for sure one phase missing or a dead VFD or spindle motor fried.
2 years 10 months ago #287887
by TimP
all wires connected properly.
I would be happy to use Rtelligent manual but it is for old version 3.1 i have 4.0 and they are different. So i cannot be sure that P1.22 is really what is described in manual because default value is different in real life. some fields some what match others just empty.
I'm pretty much sure it will run from driver itself (will try this tomorrow). And it is for sure some configuration missing, PID or maybe some thresholds. But i just don't know what exactly or from what to start. Partially because of user manual says this value should be 400 but in such place that is 0, and i don't know is it just value or different parameter that i look at.
2 years 10 months ago #287921
by Solvarg
Replied by Solvarg on topic Servo drive config and first movement
Any error codes visible on the drive?
2 years 10 months ago #287924
by TimP
yep, usually it is `motor stall fault`
2 years 10 months ago #287925
by Solvarg
What error code (AL.???) does that correspond to?
Time to create page: 0.132 seconds
