- Thank you received: 9
Servo drive config and first movement
2 years 10 months ago #287926
by TimP
Replied by TimP on topic Servo drive config and first movement
AL.247
2 years 10 months ago #287934
by Solvarg
Replied by Solvarg on topic Servo drive config and first movement
You're up against a challenge not having the proper documentation..
I've only been able to find "RSE Series Servo System User Manual V3.1.pdf" and it does not cover AL.247
Are you able to confirm the basic motor parameters settings?
Like: Number of poles, voltage, continuous and stall current, resistance, inductance, rated and max torque..
Some drives are able to auto configure these parameters, perhaps your is.
Will be very interesting to see if you're able to run from driver itself, keep us posted.
2 years 10 months ago #287935
by TimP
I have "4.0v manual" but in fact it is 3.1 plus extra 2 pages of new error codes, all other info is same, even title inside is state 3.1v "facepalm".
Well with testing it manually also problems, because what is stated in manual doesn't work so either i do it wrong or it is again mismatch with what is in driver. I guess now i need to find windows machine and install twinCat, maybe it will help?
2 years 10 months ago #287939
by Solvarg
Does the defined motor parameters (group2000-200Eh) match your motor?
2 years 10 months ago #287940
by Solvarg
Just to confirm, is this the instruction that doesn't work?
2 years 10 months ago - 2 years 10 months ago #287942
by TimP
LED P. | Address. | Name. | Default Parameter
P00.00 | 0x2000-01 | Motor ID | 40604 --- In manual
P00.00 | - | Motor ID | 50000 --- In Reality
So is it just ID is different or i have found 40604 value under P00.16 which is not represented in manual.
if i try to take this value thru EtherCAT it shows 0, so either i do it wrong or it is 0. I do it this way
<pdo idx="1600"> <pdoEntry idx="2000" subIdx="01" bitLen="16" halPin="motor-id" halType="u32"/>
and than checking in Halshow lcec.0.0.motor-id is 0
Last edit: 2 years 10 months ago by TimP.
Time to create page: 0.201 seconds
