- Thank you received: 9
Servo drive config and first movement
2 years 10 months ago #288024
by TimP
Replied by TimP on topic Servo drive config and first movement
from alibaba
2 years 10 months ago #288034
by TimP
also have found that in manual it says that there should be 3 modes on driver display. section 4.1.3
Display selection
Parameters settings
Function operation
i don't have last one, maybe that's why i cannot find how to jog motor from driver? I have tried to select control mode as speed control mode (1) but nothing new appeared.
Display selection
Parameters settings
Function operation
2 years 10 months ago #288049
by Solvarg
Replied by Solvarg on topic Servo drive config and first movement
Hmmm...
Don't you think "Function operation" refereed to in 4.1.3 could be the same as
"Auxiliary function" in 4.3?
Seems logical but is a bit fuzzy..
Are you able to toggle (short press on M) between the modes as in 4.1.3?
If so you should have AF.XXX on the display as the last step in that loop.
2 years 10 months ago #288050
by TimP
i haven;t seen AF.XXX on screen
2 years 10 months ago #288056
by Solvarg
So after the first
short M press you see: DXX.XX
the next press you see: PXX.XX
the next press you see what?
2 years 10 months ago #288060
by TimP
DXX.XX
so there are only two options
D and P
D and P
Time to create page: 0.249 seconds
