New LinuxCNC-Ethercat git tree
2 years 2 months ago #307004 by scottlaird
I've done the same thing more than once :-)
The following user(s) said Thank You: jjdege
2 years 2 months ago - 2 years 2 months ago #308275 by zmrdko
I would like to make some minor upgrades to lcec_dems300. But I am getting errors when compiling original source code from github:
Last edit: 2 years 2 months ago by zmrdko.
2 years 2 months ago #308301 by scottlaird
The easiest fix is to install go -- `sudo apt install golang` will probably do the trick. Alternately, you can just ignore it, as it's only needed for some tools, not for the core of LCEC. You could even remove `lcec_configgen` from the `user:` target around line 83 in src/Makefile, plus the bit in `install-user` where it's installed, around line 92.
The following user(s) said Thank You: zmrdko
2 years 2 months ago #308342 by zmrdko
looks like golang did it. Thanks a lot Scott!!
2 years 2 months ago #308395 by zmrdko
I have just learned, why the lcec_dems300 is so simple. There are just very few PDOs defined. (as part of CIA402 standard I guess?).
2 years 3 days ago #313467 by m3chanist
link to fdarling's sample code if you don't already have it by now.
forum.linuxcnc.org/media/kunena/attachme...st.tar_2023-10-30.gz
Time to create page: 0.333 seconds
