New LinuxCNC-Ethercat git tree
2 years 9 months ago #290038 by tommylight
Install linuxcnc 2.9.2 and  you are good to go.
sudo apt update
sudo apt install linuxcnc-ethercat
@Rod
Make a new topic with this info so i can nail it ... make it sticky :)
Thank you and the others for all the work you have done to making it so simple to install and use EtherCAT devices with LinuxCNC.
The following user(s) said Thank You: CORBETT
2 years 9 months ago #290041 by CORBETT
@Rod Webster
Super Awesome work...   Glad you have kept this moving forward.
2 years 9 months ago #290057 by rodw
Replied by rodw on topic New LinuxCNC-Ethercat git tree
@Rod
There is no need because what is discussed here makes no difference to the installation process which already is documented in the users home folder on  2.9.1/2.9.2 ISOs via a README.md and in stickies already.
What has happened now is that the repositories hosting the hal driver have been udated with some improvements and now changes will flow through as they are made.
2 years 9 months ago #290058 by rodw
@Rod Webster
Thanks., Bjarne has been super helpful getting this all sorted out since Linucnc 2.9.1 hase been released. I'm just the conductor joining the dots to bring it all together :)
Finally the hal driver and ethercat are available to any user without any stuffing aound
2 years 9 months ago - 2 years 9 months ago #290062 by jjdege
Ok, fantastic job done, thanks!!
Why would you want to compile from source when its all in a repo now.
sudo apt update
that's what I did,
after the update LCNC gives an error and doesn't see my FR4000 device, I was thinking of entering it manually like I always have, I think it's no longer possible.
Is there a solution??
Thanks again
Last edit: 2 years 9 months ago by jjdege.
2 years 9 months ago #290065 by rodw
What error? Open from the terminal and share the output. Best to raise a seperate thread though.
Time to create page: 0.065 seconds
