New LinuxCNC-Ethercat git tree
2 years 8 months ago #292748 by scottlaird
Ah, the dreaded Yaskawa problem.
I'm not sure how difficult that would be. It's deeper in the EtherCAT stack than I've really ventured so far.
I just filed github.com/linuxcnc-ethercat/linuxcnc-ethercat/issues/287 for this. If someone has a link to fdarling's sample code from github.com/sittner/linuxcnc-ethercat/iss...uecomment-1695503270 , it'd probably be fairly helpful.
I'll keep an eye on this for now, but I want to finish the current round of CiA 402 work and make it through my backlog of Beckhoff devices before I pick up another big project.
The following user(s) said Thank You: rodw, CORBETT, m3chanist, RDA
2 years 8 months ago #293191 by CORBETT
@ Scott Laird
Replied by  scottlaird  on topic  New LinuxCNC-Ethercat git tree
Thanks! I'm not sure if I'm missing anything substantial right now, other than maybe some of the EL5xxx encoder modules, but they're rare and expensive.
Ok when you are past the CiA 402 work and ready for them, let me know and I will send you a EL5101 & EL5151.   Email me when you are ready.
Also, for the future, as (RDA) has pointed out about the Yaskawa LRW problem, I think the link you are looking for is in this thread for (fdarling)’s code.  He attached it as a tarball.   (RDA) posted to (fdarling) a few days ago about the code.
Ethercat protocol not responding - Page 5 - LinuxCNC
(RDA) offered to send Dominik Braun a Yaskawa Sigma7 setup, and I saw where he posted that he would also do the same for you.  I have the Sigma 5’s and I am also more than willing to send you a complete setup when I send you the EL5101 & EL5151.  Let me or (RDA) know if you want a setup, his would be newer though (7's).
Once again, Super Thanks for all the help with this!!!  @ Rod Webster
Replied by  rodw  on topic  New LinuxCNC-Ethercat git tree
@Coebett
With this stupid forum editor I recommend that you write your complicated long post in a text editor off line then when updates are required update the text file before pasting into the forum.
I keep my ethercat instructions in google drive. image missing /media/kunena/emoticons/smile.png
Rod, yeah your right about the forum editor!!!
Yep yep, I use a simple text editor and then copy/paste.   I keep a backup in the computer and send a copy of the .txt to my email.  Still a lot of tweaking to get it somewhat right for the forum though.  I rarely post, so I’m not a Pro like you are image missing /media/kunena/emoticons/cheerful.png
2 years 7 months ago - 2 years 7 months ago #295523 by jjdege
Hi Scottlaird
I wanted to point out: after the latest update 1.26.0.g89133c2-0
LCNC goes error,
something happened...
bye thank you
Last edit: 2 years 7 months ago by jjdege.
2 years 7 months ago #295528 by scottlaird
Sorry about that; there was a typo in 1.26.0 that was fixed almost immediately in 1.26.1, but (somehow) that didn't produce a new .deb release. 1.26.2 should be out now with the fix.
The following user(s) said Thank You: besriworld, jjdege
2 years 6 months ago #297742 by rodw
Hi Scott and the team. I just wanted to draw attention to a cia402 homing component I made a start on per this thread
forum.linuxcnc.org/ethercat/52272-cia402-homing-module-a-start
And this repo
github.com/rodw-au/cia402_homecomp
Please discuss on the other thread.
2 years 4 months ago - 2 years 4 months ago #302566 by jjdege
Hi ScottI don't know if this is the right place.I wanted to report a problem.I'm using the EasyIO, with the great work of recent times it is among the devices included in the EtherCAT drivers for LinuxCNC, up until now I had only used the digital IOs which are oknow with a retrofit I need to use the analog output for the spindle, I did some tests but I wasn't able to make it work, LinuxCNC in the HalShow displays that it works but nothing comes out on the outputs with the tester. out of curiosity I also tried the analog inputs and they don't show any signs of life. To verify, I tried the old .XML and the analog outputs and inputs work, while the digital IOs I hypothesize conflict with the LinuxCNC internal drivers, because they work in a bizarre way.
I attach the XML
File Name: ethercat-c...6-08.xml
File Size:4 KB
Thanks again for your precoius work
Last edit: 2 years 4 months ago by jjdege.
Time to create page: 0.220 seconds
