CiA 402 in 1.15.0
2 years 2 months ago #308313 by AndyDM01
Replied by AndyDM01 on topic CiA 402 in 1.15.0
I will try to get my xml posted here tomorrow
the ECR86 say version 202!?
I started of by using rodw file he suggested
didn'work
after tried the ECR60 and did the modparameter stuff
afer tried the ECR86 and did the modparameter stuff
so far i only get errors
i believe you are at least 1 level up so i was hoping you could help
2 years 2 months ago #308319 by scottlaird
Replied by scottlaird on topic CiA 402 in 1.15.0
Mind you, I don't *think* anyone has tested the ECR86 yet. I've been assuming that it's the same as the ECR60, just with more power. RTelligent is *mostly* predictable, but not entirely. For example, the "x2" models are kind of weird, probably because they're trying to cram a lot of features into a small controller, but the base ECR60 seems sane.
2 years 2 months ago #308323 by scottlaird
Actually, let me retract a bit of that -- I've tested three models:
- ECT60
- ECT60x2
- ECR60x2
I haven't tried any of the other ECR* models. IIRC the code for the ECR60 and ECT60 are basically identical (see github.com/linuxcnc-ethercat/linuxcnc-et...ces/lcec_rtec.c#L129 ); the only real difference is that one shows up in `lcec_configgen` with a modparam for `motorResolution_pulses` while the other has `controlMode`. Under the hood they're treated identically. The ECT60x2 and ECR60x2 seem identical, and IIRC the specs for the normal ECT and ECR models looked the same with very minor differences.
Can you also send me `ethercat sdos` for your ECR60? That'll help. Filtering it down to juse `ethercat sdos -p XXX`, where XXX is your ECR's Ethercat slave ID would be best.
2 years 2 months ago #308387 by AndyDM01
I can't get sdos list from the ECR86
2 years 2 months ago #308390 by AndyDM01
I think i might be on to something after following your lead...
I don't have anythin rtec in src/lcec
anyway to add it there?
2 years 2 months ago #308392 by AndyDM01
File Name: mpcnc_plas...8-22.hal
File Size:3.58 KB
File Name: mpcnc_plas...conf.xml
File Size:7.22 KB
for some reason it didn't make the click in my head yet image missing /media/kunena/emoticons/sad.png
Time to create page: 0.419 seconds
