EasyCAT Arduino shield
  • zmrdko
  • zmrdko's Avatar Topic Author
  • Elite Member
  • Elite Member
25 Mar 2024 14:46 #296722 by zmrdko
EasyCAT Arduino shield was created by zmrdko
Hello,
I have acquired EasyCAT shield for Arduino. It's working pretty well and very customizable.
github.com/zmrdko/3DWorks_EasyCAT
Here is Arduino sketch derived from github.com/AlexmagToast/LinuxCNC_ArduinoConnector
The following user(s) said Thank You: tommylight, meister, scottlaird, Steph99de
25 Mar 2024 15:10 #296725 by meister
Replied by meister on topic EasyCAT Arduino shield
cool, this is the cheapest ethercat hardware i know
25 Mar 2024 20:40 #296769 by pippin88
Replied by pippin88 on topic EasyCAT Arduino shield
What ethercat slave controller does it use?
Other interesting device is Mikroe Ethercat Click
www.mikroe.com/ethercat-click
26 Mar 2024 07:20 #296795 by RDA
Replied by RDA on topic EasyCAT Arduino shield
I did not documentation in the bausano site but I assume this is just the LAN9252 shield? Or does it have also an MCU so that you can plug a shield into this board?
26 Mar 2024 07:22 - 26 Mar 2024 07:22 #296796 by RDA
I dont know why anyone would design a board with only one LAN? Its not like its a restriction of the chip or anything like that, cost wise makes quite a small difference etc.
I dont see this to be a very useful product.
Last edit: 26 Mar 2024 07:22 by RDA.
26 Mar 2024 09:21 #296799 by meister
the EtherCAT Click has two ports, the first picture is somewhat misleading
The following user(s) said Thank You: tommylight, RDA
26 Mar 2024 10:26 #296803 by RDA
Aah so the J45 is a stacked one, now it makes more sense.
Thanks for clarifying!
  • Moderator
  • Moderator
26 Mar 2024 11:26 #296809 by tommylight
Replied by tommylight on topic EasyCAT Arduino shield
It sure is, looks like a single port connector, while it does explicitly mention the chip has 2 full speed 100M ports with auto negotiation.
  • zmrdko
  • Elite Member
  • Elite Member
26 Mar 2024 13:49 #296815 by zmrdko
Replied by zmrdko on topic EasyCAT Arduino shield
same: LAN9252
this is maybe the same thing
  • zmrdko
  • Elite Member
  • Elite Member
26 Mar 2024 13:50 #296816 by zmrdko
just LAN9252 shield - it requires arduino or nucleo to be attached and running certain code
Time to create page: 0.191 seconds
