EasyCAT Arduino shield
- zmrdko
- Thank you received: 49
02 Apr 2024 22:06 #297473
by zmrdko
When you decide to use EtherCAT, you will use EtherCAT servo/stepper drives.
Replied by zmrdko on topic EasyCAT Arduino shield
Can you specify in more detail, what is your controller and what kind of motors you want to control?since i don't want to open a new thread, i'll just ask here:
I have now received my Ethercat Click and I am wondering
if it is possible to control several motors with one EtherCat client ?
- meister
- Thank you received: 502
03 Apr 2024 07:12 #297489
by meister
Replied by meister on topic EasyCAT Arduino shield
i only ever see controls for one stepper per esc and wonder whether it would be possible to control several motors with, for example, an arduino with a lan9252, purely in terms of the protocol
- pippin88
- Thank you received: 51
03 Apr 2024 07:20 #297490
by pippin88
Replied by pippin88 on topic EasyCAT Arduino shield
There are ethercat slaves for two steppers and more.
Examples:
EL7062 2-channel EtherCAT Terminal
Rovix ESD-A6 6-axis EtherCAT stepper drive
Examples:
- meister
03 Apr 2024 07:22 #297491
by meister
ahh, great, thank you very much.
somehow the topic of ethercat is a bit of a challenge for me,
but it will get better
- jjdege
- Thank you received: 38
03 Apr 2024 19:59 - 03 Apr 2024 20:00 #297534
by jjdege
Thanks to him the fantastic world of LCNC opened up to me
Replied by jjdege on topic EasyCAT Arduino shield
the FR400 is a slave that manages 5 open loop steppers with I/O, which can be implemented, to manage a CNC.i only ever see controls for one stepper per esc and wonder whether it would be possible to control several motors with, for example, an arduino with a lan9252, purely in terms of the protocol
Last edit: 03 Apr 2024 20:00 by jjdege.
- meister
20 Jun 2025 08:51 #330557
by meister
wow, I've had the EtherCat click board lying around for over a year
My problem the whole time was that I didn't have Windows and didn't want to use one.
Now I have found a way to do everything under Linux, i.e. create EEProm from the XML and also flash it via EtherCat, all without TwinCat.
In the meantime I can put my desired config on the LAN9252 and read and write all values via lowlevel spi driver.
only one step is missing to adapt the RIO interface over EtherCat
- Hakan
- Thank you received: 454
20 Jun 2025 09:52 #330560
by Hakan
Replied by Hakan on topic EasyCAT Arduino shield
Can you share how to create the eeprom content from an XML file?
- meister
20 Jun 2025 10:15 #330562
by meister
what will you pay me for it ?
;P
Converter:
github.com/synapticon/siitool
eepromtool (write flash):
github.com/OpenEtherCATsociety/SOEM/blob...romtool/eepromtool.c
;P
Converter:
- meister
20 Jun 2025 10:23 #330563
by meister
create:
check:
$ siitool -m -c -o eeprom.bin esi.xml
= eeprom.bin generatedcheck:
$ siitool -p eeprom.bin
Error, SII probably malformed. No 0xffff at the end found
First print preamble and config
Preamble:
PDI Control: ................ 0x0c80
PDI Config: ................. 0xee42
Sync Impulse Length: ........ 2000 ns (raw: 0x00c8)
PDI Config 2: ............... 0x0000
Configured Station Alias: ... 0x0000
Checksum of Preamble: ....... 0x003c (ok)
Identity:
Vendor ID: ................ 0x00400000
Product ID: ............... 0x00000715
Revision ID: .............. 0x00002ef8
Serial Number: ............ 0x00000000
Default mailbox settings:
Bootstrap Mailbox:
Received Mailbox Offset: .. 0x0000
Received Mailbox Size: .... 0
Send Mailbox Offset: ...... 0x0000
Entry 8:
Entry Index: .............. 0x60fd
Subindex: ................. 0x00
String Index: ............. 64 (Digital inputs)
Data Type: ................ 0x07 (Index in CoE Object Dictionary)
Bitlength: ................ 32
- Hakan
20 Jun 2025 10:52 #330565
by Hakan
Ok, I have seen those.
When you write an eeprom this way and then list the pdos with "ethercat pdos", do you see the ones you expect to see?
Time to create page: 0.134 seconds
