EasyCAT Arduino shield
20 Jun 2025 10:55 - 20 Jun 2025 10:59 #330566 by meister
Replied by meister on topic EasyCAT Arduino shield
accidentally flashed my ethercat servo with something wrong, and restored everything with this tool and the original esi xml
so yes, it really works
I use it to configure my LAN9252 board
EDIT:
uhhh, found this site: markosankovic.github.io/2016/06/28/esi-to-sii-binary.html
i think i need to test this '
ethercat sii_write ...
I must have overlooked it somehow :)
Last edit: 20 Jun 2025 10:59 by meister.
20 Jun 2025 15:53 #330581 by meister
because of the strange licenses from siitool i will write my own in python
20 Jun 2025 16:26 #330583 by Hakan
Replied by Hakan on topic EasyCAT Arduino shield
I see, the "-m" flag makes it write the pdos.
But what about the sdos? I don't see them coming over.
20 Jun 2025 16:39 #330584 by meister
I haven't seen it yet either :( but I haven't used it yet either
21 Jun 2025 06:15 - 21 Jun 2025 06:16 #330616 by Hakan
The xml to eeprom translation is a missing piece. With the pdos and sdos. Siitool comes halfway.
Currently I see no other option than to use TwinCAT. If there was a way for TwinCAT to only do
the translation of xml into an eeprom binary file that would help. But no, I have to take out the card
from the machine and bring it to the Windows/Twincat machine and flash the eeprom from the xml file
with TwinCAT.
If you like JavaScript, you can start from the eeprom_generator which already can do the eeprom content,
without pdos and sdos again. There is a src/generators/EEPROM.js you can have a look at.
EasyCAT uses LAN9252 I have read so should be directly usable.
github.com/MetalMusings/MyOwnEtherCATDev...ils/EEPROM_generator
Last edit: 21 Jun 2025 06:16 by Hakan.
21 Jun 2025 12:00 #330628 by meister
already a good starting point :)
github.com/multigcs/esitool
The following user(s) said Thank You: Hakan
21 Jun 2025 15:25 #330635 by meister
new discovery, there is no sdos data in the eeprom.
could not find any in the documentation or in a sanmotion servo eeprom, the data is probably read from the firmware.
21 Jun 2025 16:22 #330641 by Hakan
You are right.
I read out eeprom from a slave I know has SDOs.
But nothing with the SDO names in the eeprom bin file.
So, it is possible the siitools -m could produce a good eeprom.
I'll test later this evening, I have a device I can experiment with.
21 Jun 2025 18:48 - 21 Jun 2025 18:58 #330653 by Hakan
Yes it works! Awesome!
That -m flag made all the difference.
I took the XML file and generated an eeprom content with
siitool -m < esi.xml > eeprom.bin
wrote that to the eeprom with
ethercat sii_write -p 3 eeprom.bin
Made sure to reset the device and do a
ethercat rescan
And yes yes yes, it works. Thanks man. Will save me a lot of walking
between the workshop and the "office".
Last edit: 21 Jun 2025 18:58 by Hakan.
22 Jun 2025 21:02 #330727 by meister
ready for testing:
github.com/multigcs/esitool/
there are some testfiles in tests/
and they are all bit exactly as generated by the siitool
but i need more testfiles and maybe some tester
Time to create page: 0.259 seconds
