- Thank you received: 51
That could be done, just depends on what the definition of low cost is. If you made 100 of them and gave them to friends it'd cost you $20ea. If I complied with the ETG stuff, best case is $40 as it would still cost me $20 to make them and I'd have to offload quite a few just to recoup the cost of the CTT stuff.Unmet needs:
Low cost IO
- example: ethercat IO module on gantry for limit switches, home switches, touch probe. Just need Ethernet cable and power from control box to the gantry
- multiple ethercat esc can do 16 GPIO without any MCU / FPGA
For "lots of IO" it's a bit trickier. I'd have to think about it You can obviously use an MCU over SPI to the ESC to get the MCU's IO. Maybe those exotic ESCs have something exotic, not sure. Another possible option is to use multiplexors off the ESCs IO, I think that would be a reasonable way to do it.Lots of IO at reasonable cost - even cheap Chinese undocumented IO are $100+ for 16 IO, compare to Mesa where you get 48 IO
We should be able to have lots of IO for reasonable cost
www.bausano.net/images/arduino-easycat/E...FT_display_AN003.pdfLow cost HMI
The link in the first post the guy has that. They work but he's having issues. hardware wise it's not difficult. Not quite sure what issues he's having or what's wrong with the code. Remora targets STM32 and I think they have good stepgens, not sure if that codes portable or not. Either way If he get the code issues resolved it shouldn't be an issue to use that code in any ethercat project.Step generator. To link existing step/dir servos/steppers into ethercat
There's about $30-40 involved in even looking at an EtherCAT ESC when it's something that is to be sold. You can buy that chip for $12 and use it all day. Nobody can sell you anything with that chip on it for less than $30-40 as I explained earlier or they're losing money so that's the place where ya start. For what you're mentioning here if you bought a Mikro Click and an BTT Octopus off Amazon, you're at $100 and that's the best price you could ever get for that combined device...nobody could go near it. Now, do you want to but the $100 thing, or a Mesa card? You'd probably just buy the Mesa card and you'd be better off for it.With a "simple" ethercat slave controller (ESC) such as LAN9252 or AX58100 there are two broad approaches:
1. Separate ESC module and MCU/FPGA module with SPI connection
- advantage that MCU/FPGA module could be used with other SPI options such as RPI or SPI ethernet adaptor. This would increase market size substantially.
- could produce different modules for different needs, e.g. step/gen module, all GPIO module rather than one "jack of all trades" module
- part count might be a bit higher
My current project uses a keypad I made with 4 16bit I2C IO expanders. I2C expanders will be a thing with my EtherCAT project.2. Integrated ESC and MCU/FPGA on one PCB
With both options:
Ideal to have ability to have expansion modules to add more GPIO etc.
?over i2c or SPI
For EtherCat only: The major need I think is for low cost GPIO.
However it would be great to have open source hardware design for general use. Which SPI interfaced hardware might be ideal for versatility of use with EtherCat/Ethernet/on board SPI.
Currently Remora (for example) mainly depends on 'hacking'/repurposing of closed source boards that are subject to change without notice
Personally I'm not doing anything with FPGAs, that's not my forte. The open source thing is the link I posted in the very first post when I asked "Why doesn't anyone use stuff like this"....did ya look at it? It sounds like exactly what you're looking for there.
Doesn't really make a difference. A comparable STM32 is $3-6 @qty1. It's good for something tightly integrated, but for something like this it's better to be able to change out the MCU for a bigger/smaller/faster one. It's just saving board space, STM32s only need some caps and a crystal...it's not a big deal.There is also LAN9255 - EtherCAT Device with integrated Cortex M4F Microcontroller
$17 USD in single part quantity, <$14 in 100 qty.
