- Thank you received: 51
Lol I doubt you'd pay $8 for one. What do you use an HMI for? Can't say I've seen alotta HMIs around here. Either way you'd have to code the entire interface yourself. I can make a touchscreen SPI HMI but I have no idea how to make that type of UI and I doubt many other people would want something like that.Ethercat module for suitable HMI would be good.
I'm not going to pay $1000 for one.
It sounds like you're talking about IO for a control panel.....That's literally what I'm making, I mentioned it several times. I already have a 32 button/LED keypad via I2C IO expander, just gotta get the code into the EtherCAT slave device.Need:
Encoder counter for MPG wheel - 100 PPR
Inputs for rotary encoders for feed override, rapid override, spindle override - ?20PPR ?general GPIO input fast enough
Lots of inputs for buttons - so the usual 16 input Ethercat cards are unlikely suitable
Few outputs for indicators/LEDs
Just the Beckoff stuff that's astronomical in cost and some servo drives.
I happened to be working on a PCB with pretty much the same hardware but I was searching for what code is currently out there when I came across that. Glad to see someone's done some of that work. I just thought it was odd that I see alot of talk about EtherCAT but nobody using stuff like this, or modules that don't cost $500 each. Honestly the EtherCAT chip itself has 16 GPIO so a pretty simple EtherCAT IO board can be made for like $20
I came across that because I'm actually doing almost the same thing right now. I was kind of surprised because the components are readily available and not all that expensive yet I haven't seen anything EtherCAT that's actually useful really spoken about here.
That's not an open design bud, sorry if that was unclear. To clarify, none of the PCBs I'm talking about making are open designs. Most of the stuff I make is only made cuz it goes into something else....and I can't open source that. That's the case with whatever I'm talking about here.pippin88 post=297263 userid=16922
That's great. I look forward to when you share the design with the community.
Beckhoff have a number of Ethercat modules like the EL7031 which are step generators for stepper motors.For a new system, there would be no role for ethercat -> stepgen card -> servo/stepper.
