Yes this is exactly the behavior I ment to describe. I observed the dmesg while manually trying to switch the states:
ethercat state -p0 INIT
Display shows "_10ry", not flashing, and dmesg:
[Apr27 15:54] EtherCAT DEBUG 0-0: Changing state from PREOP to INIT.
[ +0.000003] EtherCAT DEBUG 0-0: Configuring...
[ +0.000874] EtherCAT DEBUG 0-0: Now in INIT.
[ +0.000001] EtherCAT DEBUG 0-0: Clearing FMMU configurations...
[ +0.000277] EtherCAT DEBUG 0-0: Clearing sync manager configurations...
[ +0.000277] EtherCAT DEBUG 0-0: Clearing DC assignment...
[ +0.000278] EtherCAT DEBUG 0-0: Finished configuration.
[ +0.010270] EtherCAT 0: Slave states on main device: INIT.
ethercat state -p0 SAFEOP
Display shows "_20ry", the two is flashing, and dmesg:
[Apr27 15:57] EtherCAT DEBUG 0-0: Changing state from INIT to SAFEOP.
[ +0.000008] EtherCAT DEBUG 0-0: Configuring...
[ +0.000692] EtherCAT DEBUG 0-0: Now in INIT.
[ +0.000003] EtherCAT DEBUG 0-0: Clearing FMMU configurations...
[ +0.000297] EtherCAT DEBUG 0-0: Clearing sync manager configurations...
[ +0.000305] EtherCAT DEBUG 0-0: Clearing DC assignment...
[ +0.000304] EtherCAT DEBUG 0-0: Configuring mailbox sync managers...
[ +0.000003] EtherCAT DEBUG 0-0: SM0: Addr 0x1000, Size 128, Ctrl 0x26, En 1
[ +0.000007] EtherCAT DEBUG 0-0: SM1: Addr 0x1100, Size 128, Ctrl 0x22, En 1
[ +0.000294] EtherCAT DEBUG 0-0: Assigning SII access to PDI.
[ +0.001423] EtherCAT DEBUG 0-0: Now in PREOP.
[ +0.000003] EtherCAT DEBUG 0-0: Assigning SII access back to EtherCAT.
[ +0.000261] EtherCAT DEBUG 0-0: SM2: Addr 0x1200, Size 0, Ctrl 0x64, En 0
[ +0.000005] EtherCAT DEBUG 0-0: SM3: Addr 0x1300, Size 0, Ctrl 0x20, En 0
[ +0.000808] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ +0.000311] EtherCAT ERROR 0-0: AL status message 0x001E: "Invalid input configuration".
[ +0.000537] EtherCAT 0-0: Acknowledged state PREOP.
[ +0.006737] EtherCAT 0: Slave states on main device: PREOP.
ethercat state -p0 OP
[Apr27 16:00] EtherCAT DEBUG 0-0: Changing state from PREOP to OP.
[ +0.000002] EtherCAT DEBUG 0-0: Configuring...
[ +0.000881] EtherCAT DEBUG 0-0: Now in INIT.
[ +0.000000] EtherCAT DEBUG 0-0: Clearing FMMU configurations...
[ +0.000278] EtherCAT DEBUG 0-0: Clearing DC assignment...
[ +0.000279] EtherCAT DEBUG 0-0: Configuring mailbox sync managers...
[ +0.000001] EtherCAT DEBUG 0-0: SM0: Addr 0x1000, Size 128, Ctrl 0x26, En 1
[ +0.000001] EtherCAT DEBUG 0-0: SM1: Addr 0x1100, Size 128, Ctrl 0x22, En 1
[ +0.000274] EtherCAT DEBUG 0-0: Assigning SII access to PDI.
[ +0.000802] EtherCAT DEBUG 0-0: Now in PREOP.
[ +0.000001] EtherCAT DEBUG 0-0: Assigning SII access back to EtherCAT.
[ +0.000272] EtherCAT DEBUG 0-0: SM2: Addr 0x1200, Size 0, Ctrl 0x64, En 0
[ +0.000001] EtherCAT DEBUG 0-0: SM3: Addr 0x1300, Size 0, Ctrl 0x20, En 0
[ +0.000838] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ +0.000274] EtherCAT ERROR 0-0: AL status message 0x001E: "Invalid input configuration".
[ +0.000835] EtherCAT 0-0: Acknowledged state PREOP.
Startup of LCNC:
Display shows "_F0ry", not flashing, and dmesg:
[ +0.001993] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms.
[ +0.000001] EtherCAT DEBUG 0-0: ref_time=767542016736603000
[ +0.000001] EtherCAT DEBUG 0-0: app_time=767542021916008181
[ +0.000001] EtherCAT DEBUG 0-0: start_time=767542022016008181
[ +0.000001] EtherCAT DEBUG 0-0: cycle=1000000
[ +0.000001] EtherCAT DEBUG 0-0: shift_time=0
[ +0.000001] EtherCAT DEBUG 0-0: remainder=405181
[ +0.000001] EtherCAT DEBUG 0-0: start=767542022016603000
[ +0.000000] EtherCAT DEBUG 0-0: Setting DC cyclic operation start time to 767542022016603000.
[ +0.001992] EtherCAT DEBUG 0-0: Setting DC AssignActivate to 0x0300.
[ +0.004009] EtherCAT DEBUG 0-0: Now in SAFEOP.
[ +5.001992] EtherCAT ERROR 0-0: Timeout while setting state OP.
[ +0.007631] EtherCAT 0: Slave states on main device: SAFEOP.
[ +12.904001] EtherCAT 0: Slave states on main device: SAFEOP + ERROR.
[ +0.007998] EtherCAT DEBUG 0-0: SAFEOP -> SAFEOP + ERROR.
I find this interesting when manually switching states:
