- Thank you received: 10
[Apr20 19:33] EtherCAT: Requesting master 0...
[ +0.000002] EtherCAT: Successfully requested master 0.
[ +0.000175] EtherCAT 0: Domain0: Logical address 0x00000000, 196 byte, expected working counter 1.
[ +0.000002] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 196 byte, type LWR.
[ +0.000006] EtherCAT 0: Master thread exited.
[ +0.000001] EtherCAT 0: Starting EtherCAT-OP thread.
[ +0.000021] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[ +4.295428] EtherCAT ERROR 0-0: Timeout while setting state OP.
[ +0.007773] EtherCAT 0: Slave states on main device: SAFEOP.
[ +12.904002] EtherCAT 0: Slave states on main device: SAFEOP + ERROR.
Sorry I don't know how to format code here.=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000766
Product code: 0x00000402
Revision number: 0x00000204
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 3652581971 0 0
1 MII down closed no - - - -
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x1100/128
Supported protocols: CoE
General:
Group: EtherCAT Driver
Image name:
Order number:
Device name: LC10E_V1.04
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
