Problems with Lichuan Ethercat servo drive
1 year 7 months ago #323270 by jdowsonjr
LC-E series drives dont have an auto tune feature. Has anyone successfully tuned these drives even when only one motor is used per axis (not a gantry)? Considering if I buy a kit as well over Inovance or Leadshine
1 year 7 months ago #323290 by ihavenofish
I'm still waiting to see these in proper functional use on a machine too.
These are very appealing to spec on my machine, but I want someone else to make sure it works first, hahaha.
1 year 7 months ago #323293 by LCR
They do seem to work. I've spent about 3 hrs tuning these so far. I'll have a hopefully final go next week. I've got 4 1kw servos (gantry). There are enough details in the manual to do the tuning. The velocity feed forward from Linux Cnc really helps with following error to a ramp, which is what I'm testing. I wish there was a way to restart communication without restarting the drives. It is tedious using the buttons on the drives. If I get a satisfactory procedure I'll write it up.
1 year 7 months ago - 1 year 7 months ago #323382 by Philip Lydin
im gonna ttry and use them on my lathe retrofit. To see more info look here and feel free to ask some questions!
forum.linuxcnc.org/38-general-linuxcnc-q...ofitt-feeler-ftc-280
Last edit: 1 year 7 months ago by Philip Lydin.
1 year 7 months ago #323397 by ihavenofish
I just tuned my omron ethercat servos. I fear manual tuning on these lichuans, haha. How are you doing it, just scoping it in twincat or linuxcnc? or do they have an app?
1 year 7 months ago #323708 by Darium
Dont know if this help but I managed to tune the following error to around 20 micron at 3000mm/min. The drive is non ethercat, just regular step+dir. Tuning it was quite trivial. Turning speed forward gain to 100% should reduce the following error significantly
Time to create page: 0.270 seconds
