Leadshine EL8 interruptions
  • Moderator
  • Moderator
12 May 2024 21:12 #300474 by tommylight
Replied by tommylight on topic Leadshine EL8 interruptions
In a terminal
latency-histogram --nobase --sbinsize 1000 --show
leave it on, click on glxgears 5 to 10 times, watch some youtube, and take a screenshot after half an hour.
13 May 2024 20:22 #300526 by gastlth1
Replied by gastlth1 on topic Leadshine EL8 interruptions
after a runtime of about half an hour with glxgears in different variants, the histogram according to the appendix was shown
  • Moderator
  • Moderator
13 May 2024 20:24 #300527 by tommylight
That is perfectly OK.
Try in a terminal:
sudo lspci -v | grep Intel
or
sudo lspci -v | grep Ethernet
what do those return?
The following user(s) said Thank You: gastlth1
14 May 2024 16:22 - 14 May 2024 16:24 #300583 by gastlth1
Which of these components can negatively influence the performance of the constellation Linuxcnc with Ethercat?
Last edit: 14 May 2024 16:24 by gastlth1.
14 May 2024 19:11 - 26 May 2024 22:12 #300592 by gastlth1
After a quarter of an hour of running the program, I spontaneously got the error message again, as shown in the attachment.Is this the latency time, can it be caused by the Ethercat network system or is another explanation plausible?
Last edit: 26 May 2024 22:12 by gastlth1.
30 May 2024 06:47 #301820 by gastlth1
I have now achieved a situation where the system ran for 1.5 hours without interruption during test runs. To do this, I removed the EK1100 with several IOs and am only connected to the servo controllers with ethercat,
Too bad that I had to realize that ethercat with Linuxcnc does not run completely and consistently stable.
What do you think, what could be changed in the system so that this would be the case?
Time to create page: 0.428 seconds
