Amplifier fault
- cncLab
04 May 2024 08:36 #299693
by cncLab
Amplifier fault was created by cncLab
Being inspired by Hakan video: (Thank you Hakan)
I have installed Linuxcnc 2.9.2 on Raspi 5 using Raspberry Pi 5 OS based on Debian Bookworm, located here: linuxcnc.org/downloads/
I have also installed successfully the CiA402 supporting sw as mentioned in the forum
My hardware is: Beckhoff EL1100, Beckhof 1809, Beckhof 2809, Two RTelligent drives ECT60
and two motors StepperOnline 17HS19-2004S1 (Nema 23 closed loop)
I try to execute the standard code that comes with Axis Lathe.
Unfortunatelly and although the whole system becomes Ready, immediately after program execution run
I get the error "joint 1: amplifier fault"
Can anybody indicate what is wrong with my system and maybe point to me any direction that can help to overcome this problem?
What "joint 1: amplifier error" even means?
command Ethercat master returns:
cnc@raspberrypi:~/linuxcnc/configs/sim.axis$ ethercat master
Master0
Phase: Operation
Active: yes
Slaves: 5
Ethernet devices:
Main: d8:3a:dd:c2:2c:4b (attached)
Link: UP
Tx frames: 7241313
Tx bytes: 758342228
Rx frames: 7241312
Rx bytes: 758342128
Tx errors: 0
Tx frame rate [1/s]: 1000 1000 1000
Tx rate [KByte/s]: 102.5 102.5 102.4
Rx frame rate [1/s]: 1000 1000 1000
Rx rate [KByte/s]: 102.5 102.5 102.4
Common:
Tx frames: 7241313
Tx bytes: 758342228
Rx frames: 7241312
Rx bytes: 758342128
Lost frames: 0
Loss rate [1/s]: 0 -0 0
Frame loss [%]: 0.0 -0.0 0.0
Distributed clocks:
Reference clock: Slave 0
DC reference time: 768116871044400000
Application time: 768124063237637764
2024-05-04 07:47:43.237637764
and the ethercat slaves returns:
cnc@raspberrypi:~/linuxcnc/configs/sim.axis$ ethercat slaves
0 0:0 OP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 OP + EL1809 16K. Dig. Eingang 24V, 3ms
2 0:2 OP + EL2809 16K. Dig. Ausgang 24V, 0.5A
3 0:3 OP + ECT60V202(COE)
4 0:4 OP + ECT60V202(COE)
I attach my lathe.ini, second.hal and second.xml files I currently use
Master0
Phase: Operation
Active: yes
Slaves: 5
Ethernet devices:
Link: UP
Tx frames: 7241313
Tx bytes: 758342228
Rx frames: 7241312
Rx bytes: 758342128
Tx errors: 0
Common:
Tx frames: 7241313
Tx bytes: 758342228
Rx frames: 7241312
Rx bytes: 758342128
Lost frames: 0
Distributed clocks:
- pippin88
- Thank you received: 51
04 May 2024 09:12 #299698
by pippin88
Replied by pippin88 on topic Amplifier fault
Simple troubleshooting: have you tried swapping the X and Z drives (ECT60s)? Just change order of the ethercat cables.
Does the fault follow the current Z drive (fault should become amplifier joint 0 fault)?
- Thank you received: 4647
04 May 2024 09:23 #299701
Replied by andypugh on topic Amplifier fault
In this context the "Amplifier" is the actual servo drive. (historically they converted a low current +/- 10V control voltage into hundreds of volts and tens of amps, so really were an amplifier. The term is rather less accurate now.
- Thank you received: 4128
04 May 2024 23:57 #299772
Replied by rodw on topic Amplifier fault
Are your encoders really 10000 pulses per rev?
The rtelligent drive defaults are 800
- cncLab
08 May 2024 07:17 #300095
by cncLab
Replied by cncLab on topic Amplifier fault
Dear all,
First of all, thanks for your support.
Finally I discovered what the problem was and since is kind strange this info might be useful to others as well.
Actually, the encoder pin layout for STEPPERONLINE motor model 23HS22-4004D-E1000 is WRONG! In motors manual and in relevant site the pins are referred to as 2:Vcc, 3:EGND, 1:EA+, 13:EA+, 11:EB+, 12:EB-
I followed the cable from the D-Connector up to motor PBC and I found out that the actual pins are:
2:Vcc, 3:EGND, 1:EB+, 13:EB-, 11:EA+, 12:EA-
Following the relevant changes, now my ETHERCAT system works perfectly (up to this point!)
Thanks again for your interest
Time to create page: 0.168 seconds
