Panasonic servo driver(xml file)
- Mehta_123
18 May 2024 09:05 - 18 May 2024 09:21 #300902
by Mehta_123
Panasonic servo driver(xml file) was created by Mehta_123
Hello !!
I am having trouble to run servo motor, I have panasonic MBDLN25BE model servo driver, I did find the xml file but its not compatible with LCNC.
I have installed Ethercat in my PI4 and able to detect 2 slaves (1st is Beckhoff EK1100 and second is MBDLN25BE). I have read xml file examples across forum and compare/made xml file of my own and solved coming errors of base period, but still not able to run motor.
Attaching driver's xml file, xml file that I made and hal/ini file and xml file genrated from "ethercat xml" command for your reference.
Can you please help me with this ?
Thanks.
Thanks.
Last edit: 18 May 2024 09:21 by Mehta_123.
- msantaji1
17 Nov 2024 17:54 #314683
by msantaji1
Replied by msantaji1 on topic Panasonic servo driver(xml file)
Check attachment for working setup of Panasonic Servo with ethercat driver and delta RTU-ECAT for IO
Santaji Mane
Santaji Mane
- msantaji1
17 Nov 2024 17:58 #314684
by msantaji1
Files were missed
Time to create page: 0.375 seconds
