Linuxcnc's Ethercat in Raspberry pi-5
2 years 3 months ago #305190 by seyad
For Ethercat  installation i followed this video (
).After that  I strated test ethercat following his steps while executing lathe.ini file error came. Bellow attached error report.
File Name: Linuxcnc.report.txt
File Size:5.6 KB
2 years 3 months ago #305469 by jjdege
HI
Just wanted to confirm that everything is working
I downloaded and installed the LinuxCNC file for Raspberry Pi 5
followed the stiky written by Rod for the EtherCAT drivers and everything works
my CNC moves like with the PC
the only thing you can't manage is the display
but it's all great
Thank you!
2 years 3 months ago #305474 by rodw
This is for the 4B but you might be able to set the screen resolution in config.txt
pimylifeup.com/raspberry-pi-screen-resolution/
But this file might be in a sub folder
The following user(s) said Thank You: jjdege
2 years 3 months ago #305606 by seyad
yes, if you use pre-developed image, Everything work well. But Actually i am trying build linuxcnc from source file and ethercat too, there only i am facing issue
2 years 2 months ago #308578 by jjdege
hello
to update what I wrote here
I resumed the installation of LCNC + etherCAT on native Raspberry Pi 5 OS.
I turned the raspy back on and there were some updates to install, after doing this I ran this in the terminal
sudo dpkg-reconfigure ethercat-dkms
everything works on native OS with audio and video graphics ok!!!
The following user(s) said Thank You: zmrdko
1 year 10 months ago #317169 by vanquang
Dear jjdege.
How can you solve the error when you install the ethercat package by command "sudo apt install -y linux-headers-(uname -r) ethercat-master linuxcnc-ethercat?
Time to create page: 0.062 seconds
