SCATECH EV1616DN - Example config
- darrylb123
15 Mar 2025 05:49 #323991
by darrylb123
Replied by darrylb123 on topic SCATECH EV1616DN - Example config
Assuming the Mesa 7i92 is my answer, I'm in Australia, I looked for a local distributor and a 10 year old post on CNCZone from rodw said that he too was Australian and had them for sale?? Is this still the case and how do I go about buying one?
- unknown
- Thank you received: 323
15 Mar 2025 10:11 #323996
by unknown
Replied by unknown on topic SCATECH EV1616DN - Example config
Yeah I'm no too sure about that.
Where abouts in Oz are ya.
- Thank you received: 4153
15 Mar 2025 19:24 #324019
Replied by rodw on topic SCATECH EV1616DN - Example config
The closest distributor is in New Zealand but it's probably easier to order from Mesa direct.Assuming the Mesa 7i92 is my answer, I'm in Australia, I looked for a local distributor and a 10 year old post on CNCZone from rodw said that he too was Australian and had them for sale?? Is this still the case and how do I go about buying one?
- darrylb123
16 Mar 2025 04:23 #324040
by darrylb123
Central Queensland
- darrylb123
06 Aug 2025 09:45 #332950
by darrylb123
Ended up using the EV1616DN for 'slow' signals such as limits and lights. Used a PCIe parallel port card and Mach3 breakout board for the steppers. Stepconfig used for the mach3 card config (with modifications for homing) and hand coded the hal file. Works pretty well and now I have plenty of I/O for further development.
ethercat-config.xml
ev1616.hal
Ha
ethercat-config.xml
ev1616.hal
Ha
08 Aug 2025 10:14 - 08 Aug 2025 10:15 #333040
Great work. time to adopt Ethercat all the way!. rtelligent and leadshine both have Ethercat stepper drives. If open loop, both have two channel drives. Not sure wat you have but for a gantry XYYZ machine, you only need two drives! There is some native support in the lcnc Ethercat driver. Should be a breeze now you know how to write the xml file
Last edit: 08 Aug 2025 10:15 by rodw.
Time to create page: 0.264 seconds
