Amplifier Fault ECT60 Closed Loop
2 years 2 months ago #308572 by rodw
I can't work this issue out.
I'm building a simple testbed for CIA402 homing that has two joints. Both are using an Rtelligent ECT60 drive. One is closed Loop, (rtelligent NEMA23 stepper) the other is Open loop NEMA23 (Sanyo Denki stepper)
Both joints work perfectly in open loop mode but if I set the Rtelligent to be closed loop, I get  a little bit of movement then it stops with an amplifier fault.
It does not matter if I use a generic driver, the ECT60 driver or the basic_cia402 driver. Behavior is the same.
It would be great if you could review my attached config and provide any feedback.
File Name: ect60.hal
File Size:3.37 KB
File Name: ethercat-conf.xml
File Size:533 B
File Name: ect60.ini
File Size:3.1 KB
2 years 2 months ago #308593 by tommylight
Closed loop in LinuxCNC must be tuned in LinuxCNC, for stepper systems mainly just the P and FF1 values.
For P as high as it can go without vibrations at standstill, then just back a bit to be on the safe side.
For FF1 there is a corelation that i can not recall and can not check as i am on the phone, but try some rough values like 0.4 or 0.5 or 0.6 and see how it works then some finer value changes after you get it to jog, untill you can jog at full speed without error.
2 years 2 months ago #308595 by besriworld
What error is the driver showing?
2 years 2 months ago #308599 by tommylight
Hmmmm... is the loop being closed in the drive or LinuxCNC?
If in the drive, first thing to check is the encoder wiring (if it is not factory sealed), then change motor wires to change the direction.
2 years 2 months ago #308618 by besriworld
"MAX_ACCELERATION = 5000 "
try with less acceleration ...
2 years 2 months ago #308677 by TheRoslyak
Strange. I have this kind of drive, and I didn't have any problems with it, although I didn't run it for long. Actually, when you buy it, it's initially sold as either closed-loop or open-loop, and the seller asked me about it when I purchased it. Well, I immediately chose the closed-loop one.
Time to create page: 0.358 seconds
