Amplifier Fault ECT60 Closed Loop
- Thank you received: 4153
25 Aug 2024 02:53 #308572
Amplifier Fault ECT60 Closed Loop was created by rodw
I can't work this issue out.
I'm building a simple testbed for CIA402 homing that has two joints. Both are using an Rtelligent ECT60 drive. One is closed Loop, (rtelligent NEMA23 stepper) the other is Open loop NEMA23 (Sanyo Denki stepper)
Both joints work perfectly in open loop mode but if I set the Rtelligent to be closed loop, I get a little bit of movement then it stops with an amplifier fault.
It does not matter if I use a generic driver, the ECT60 driver or the basic_cia402 driver. Behavior is the same.
It would be great if you could review my attached config and provide any feedback.
- Thank you received: 7496
25 Aug 2024 12:03 #308593
Replied by tommylight on topic Amplifier Fault ECT60 Closed Loop
Closed loop in LinuxCNC must be tuned in LinuxCNC, for stepper systems mainly just the P and FF1 values.
For P as high as it can go without vibrations at standstill, then just back a bit to be on the safe side.
For FF1 there is a corelation that i can not recall and can not check as i am on the phone, but try some rough values like 0.4 or 0.5 or 0.6 and see how it works then some finer value changes after you get it to jog, untill you can jog at full speed without error.
- besriworld
- Thank you received: 92
25 Aug 2024 13:15 #308595
by besriworld
Replied by besriworld on topic Amplifier Fault ECT60 Closed Loop
What error is the driver showing?
25 Aug 2024 13:48 #308599
Hmmmm... is the loop being closed in the drive or LinuxCNC?
If in the drive, first thing to check is the encoder wiring (if it is not factory sealed), then change motor wires to change the direction.
- besriworld
25 Aug 2024 17:47 #308618
by besriworld
"MAX_ACCELERATION = 5000 "
try with less acceleration ...
- TheRoslyak
- Thank you received: 37
26 Aug 2024 08:12 #308677
by TheRoslyak
Replied by TheRoslyak on topic Amplifier Fault ECT60 Closed Loop
Strange. I have this kind of drive, and I didn't have any problems with it, although I didn't run it for long. Actually, when you buy it, it's initially sold as either closed-loop or open-loop, and the seller asked me about it when I purchased it. Well, I immediately chose the closed-loop one.
- TheRoslyak
26 Aug 2024 08:22 #308679
by TheRoslyak
Well, and I wrote the XML manually.
26 Aug 2024 10:49 #308689
@besriworld, I was hoping you had nailed it, but not to be. Being a plasma guy, I forget about inertia! I tried disconnecting the drive and see if it runs with no load but its no better.
The fault is "Joint 1 amplifier fault"
@tommy, this ethercat drive looks after the encoder connection. I can see the DRO moving when I twist the shaft so its OK. It has automatic tuning by default and the motor and drive are a matched pair. It can be set manually, but I don't think I need to go there.
Thanks everyone for their ideas. I am still none the wiser. From memory, there is an internal error register I might publish a pin for and review.
Replied by rodw on topic Amplifier Fault ECT60 Closed Loop
Yes I have its big brother ECT86 running perfectly. I am sure I had this running in testing with no load but lost the config. I think my manual XML has been used by most people on these drives. Pretty sure its found its way into ScottLairds linuxcnc-ethercat driver too.Strange. I have this kind of drive, and I didn't have any problems with it, although I didn't run it for long. Actually, when you buy it, it's initially sold as either closed-loop or open-loop, and the seller asked me about it when I purchased it. Well, I immediately chose the closed-loop one.
- besriworld
26 Aug 2024 14:00 #308704
by besriworld
Now I saw the device.
My idea was if there will be an error if the speed/acceleration is low.
- TheRoslyak
26 Aug 2024 16:22 - 26 Aug 2024 16:32 #308716
by TheRoslyak
Again, please clarify which drive you ended up taking. Because a closed-loop drive is sold by the seller at a slightly higher price. This is probably due to the low-level firmware. They might have sent you a cheaper version.
www.rtelligentglobal.com/uploads/Rtellig...ies-User-Manual1.pdf
Last edit: 26 Aug 2024 16:32 by TheRoslyak.
Time to create page: 0.164 seconds
