problem with running ethercat
27 Aug 2024 09:32 #308781 by Abdulkareem
problem with running ethercat was created by Abdulkareem
hello guys,
i get this error when i try to run these commands
(venv) abdulkareem@debian:~$ ethercat slaves
Failed to obtain number of masters: ioctl() version magic is differing: /dev/EtherCAT0: 37, ethercat tool: 33
A probable reason is that the command-line tool
you are using is built with a different
source code version than the currently loaded
kernel module. Please install an updated version
of either the tool (ethercat) or the kernel
module (ec_master.ko).
when i try to update i found also this error which i think it may cause the above error
(venv) abdulkareem@debian:~$ sudo apt-get update
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
W: Skipping acquire of configured file '2.9-rt/source/Sources' as repository 'www.linuxcnc.org bookworm InRelease' does not seem to provide it (sources.list entry misspelt?)
W: Failed to fetch download.opensuse.org/repositories/scien...ebian_12/./InRelease  The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
can anyone help me with this error ??
27 Aug 2024 14:11 #308808 by scottlaird
Replied by scottlaird on topic problem with running ethercat
The problem with `ethercat slaves` is presumably because your kernel is running a different version of the EtherCAT code than the one that the `ethercat` command-line tool expects. If you'd recently installed an update without rebooting, then I'd expect to see the kernel version lower than the command-line version, but that's not what I see here. So that's kind of odd. The best fix would be to update and reboot. But...
IIRC they recently changed the keys for the OpenSUSE build server. I *think* the instructions in forum.linuxcnc.org/ethercat/45336-etherc...ep-by-step?start=290 should fix this. Try that, and if it runs successfully then reboot and see if everything works?
27 Aug 2024 21:22 #308853 by rodw
Replied by rodw on topic problem with running ethercat
Seems like you are running a python virtual environment. Not sure that is an issue, but Try after exiting it.
Time to create page: 0.132 seconds
