Performance issues after switching from LCNC 2.8.4 Buster to 2.9.3 Bookworm
2 years 1 week ago #313048 by BaxEDM
Ok, it seems r8168.aspm=0 or r8168.eee_enable=0 cannot be set with the grub customizer, but found another way:
sudo geany /etc/modprobe.d/r8168-dkms.conf
add the following:
# Disable Energy Efficient Ethernet
options r8168 eee_enabled=0
# Disable Active State Power Management (ASPM)
options r8168 aspm=0
Then save and close geany, then run the command:
sudo update initramfs -u
Then reboot
sudo reboot
After the reboot you can verify that the energy efficient ethernet is indeed disabled with
sudo ethtool --show-eee enp2s0
replace enp2s0 with the name of your Ethernet interface. You can get the name of your interface with the "ip a" command
If ethtool is not installed do:
sudo apt update
sudo apt install ethtool
I'm now running an endurance test with EEE disabled. Will report back here.
2 years 1 week ago #313081 by BaxEDM
Ah yes! After switching off EEE and aspm, I ran the machine for over 3 hours straight without encountering any servo following errors. I captured everything I did in order to do a full problem free installation in this procedure for my customers, this might be useful for others as well:
baxedm.com/linuxcnc-installation-for-edm...-on-linux-debian-12/
The following user(s) said Thank You: tommylight, rodw, Macwolf
2 years 1 week ago #313083 by tommylight
2 years 5 days ago - 2 years 5 days ago #313281 by rodw
Nuce writeup. I hope you don't mind but I added it to my Debian 12 document
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
Last edit: 2 years 5 days ago by rodw.
Time to create page: 0.183 seconds
