Haha, that brings back memories image missing /media/kunena/emoticons/smile.png
There are two products here in the picture
www.aliexpress.com/item/1005001579853052.html
STM32F407VET6 dev board
www.aliexpress.com/item/1005007182508975.html
LAN9252 slave dev board
The STM32's pins on the LAN93252 dev board are limited to those in the pin header, which wasn't enough.
For test it can work if the needed pins are available in the header.
One can use the LAN9252 of the kit, which is what I did and hooked it up to the STM32 dev board
where I had access to all pins.SPI+sync0,syc1,irq lines.
I now see in some searches there are other LAN9252+STM32 development boards which are better suited, maybe this one?
It can pay off to do a search. You want access to the Timer's encoder inputs, which
are different for different models so it's a puzzle.
Schema for STM32F407ZGT6 on the LAN9252 dev board
