They should definitely be called joint.0 if they don't there might be bigger problems. The "0" of course refers to the number of the joint that gives the following error.
You find the pin names here
linuxcnc.org/docs/html/man/man9/motion.9.html#JOINT%20PINS
motor-pos-cmd
motor-pos-fb
f-error
are the interesting ones.
There are tutorials on halscope out there. It's a good tool to know how to handle. Basically select the three pins in the fields down below, adjust scaling and offset (can be done later as well). Set to record every millisecond, as long as possible. Manual trigger, and trigger when you get get the following error. It keeps a buffer of recorded data so you won't miss it even if you trigger slightly afterwards. Then adjust the curves with the same scaling for motor-pos-cmd and motor-pos-fb so they can be compared, and put up f-error as well, with a proper scaling so one can see it develop.
