AX58100
1 year 10 months ago #315999 by Hakan
Replied by Hakan on topic AX58100
And for LAN9252, it is better to copy the whole lib/soes from Easercat 2000 and go from there. That should work right away.
The following user(s) said Thank You: SOLD
1 year 10 months ago #316000 by SOLD
Replied by SOLD on topic AX58100
Thank you. I will study more.
1 year 10 months ago #316045 by Hakan
I'll try to explain how the spindle-index-enable works.
This is the traditional syntax in hal to enable synchronization on index signal
linuxcnc.org/docs/html/examples/spindle...._synchronized_motion
net spindle-index-enable encoder.3.index-enable => spindle.0.index-enable
First look at what motion.spindle.M.index-enable says
spindle.M.index-enable I/O BIT
For correct operation of spindle synchronized moves,
this signal must be hooked to the index-enable pin
of the spindle encoder.
Then look at what the encoder's index-enable pin says
linuxcnc.org/docs/html/man/man9/encoder.9.html
encoder.N.index-enable bit i/o
When true, counts and position are reset to zero on the
next rising edge of Phase-Z. At the same time, index-enable
is reset to zero to indicate that the rising edge has occurred.
These three lines say a lot. This is the behavior the EtherCAT client tries to replicate.
index-enable is a I/O bit, that means read AND write variable. As mentioned, EtherCAT variables
are read OR write. The metalmusings_encoder component split index-enable in two variables
one read variable that forwards the value to the EtherCAT client, and one write variable
that when set will change index-enable, as specified above.
In the EaserCAT 3000 client, when Obj.IndexLatchEnable is set, i.e. when index-enable is set, it waits for the next Z-index interrupt, which then then zeroes the counters. This needs to be done exactly when the Z index happens, not any time afterwards. Because this happens in an ISR it communicates to the rest of EaserCAT with indexPulseFired variable. So in cb_get_inputs() when setting whether the index fired it will know that from this variable.
It is pretty indirect programming, but that is how I have been taught to communicate with ISRs.
Then it will set Obj.IndexHappened, which will go the the metalmusings_encoder component whioch will reset the i/o variable.
Not sure this clears things up, not so easy to write a good clear answer to this.
1 year 10 months ago - 1 year 10 months ago #316080 by SOLD
I'm familiar with the orient function.
After receiving your explanation, I'll go back to metalmusings_encoder.comp to double check the bindings with the GPT explanation.
Components and pins:
Component metalmusings_encoder: This component represents the encoder's function related to the index signal.
Index-c-enable pin (bit): This pin is used to control whether the index-enable signal is on or off.
Index-status pin (u32): This pin holds the status of the index signal, indicating whether the index is latched.
Index-latch-enable pin (u32): This pin is used to latch the index-enable state to synchronize it with the correct position.
Main function logic:
Initialization:
index_latch_enable = index_c_enable;
This causes index-latch-enable to follow the value of index_c_enable , if index_c_enable Set to true (high), index-latch-enable will be enabled.
When index_latch_enable is true:
If index_latch_enable is set to true (when index_c_enable is high), it checks whether index_status is true.
If index_status is true (i.e., a jitter occurs on the index signal), it resets index_c_enable to 0.
if (index_status) { index_c_enable = 0; }
This means that when the index signal is detected, index_c_enable will be reset to prevent re-jittering.
When index_latch_enable is false:
If index_latch_enable is false (i.e., not synchronized), the system will wait for index_status to trigger index_c_enable to true.
index_c_enable = index_status;
This means that index_c_enable will be set based on the state of index_status and wait for a jitter from the index signal.
Overall behavior:
When index_c_enable is true:
The system checks index_status. If index_status is true (i.e. the index is latched), index_c_enable is set to 0 to prevent re-latching.
When index_c_enable is false:
The system waits for index_status to be true to trigger index_c_enable again, which causes synchronization when the index signal is latched.
Summary:
This component handles the index-enable signal by varying the value of index_c_enable depending on the state of index_status. It causes position synchronization to occur when the index signal is latched, and when index_latch_enable is set, the system resets index_c_enable after a latch from the index, which allows position synchronization to occur at the appropriate time.
Last edit: 1 year 10 months ago by SOLD.
1 year 10 months ago - 1 year 10 months ago #316081 by SOLD
I'm trying to learn and here's the summary
Information about Name Data type in Obj Direction Data type EEPROM Generator Associated function Description
IndexLatchEnable  uint8_t        UNSIGNED8       cb_set_outputs() Enable or disable Index Pulse latch
EncPos                 double         REAL32             cb_get_inputs() + MyEncoder.currentPos() Current position of the Encoder
EncFrequency       double         REAL32             cb_get_inputs() + MyEncoder.frequency() Frequency of the Encoder
IndexStatus          uint8_t         UNSIGNED8      cb_get_inputs() + MyEncoder.indexHappened() Status of the Index Pulse
IndexByte             uint8_t        UNSIGNED8       cb_get_inputs() + MyEncoder.getIndexState() Status of the Index
Velocity                double         REAL32             cb_get_inputs() Speed ​​of the system (calculated from the Encoder or other data)
1 year 10 months ago - 1 year 10 months ago #316117 by SOLD
I think I successfully entered debug mode, but when I rotate the shaft, no change is detected in encCtn. Or I am viewing incorrect information.
image missing /media/kunena/emoticons/sad.png
Eventually, as I tested the method further, I found that it actually counted…it worked.image missing /media/kunena/emoticons/tongue.png
