AX58100
1 year 11 months ago #315426 by Hakan
Replied by Hakan on topic AX58100
With the use of SOES github.com/OpenEtherCATsociety/SOES there is no difference for me as a programmer.
There is a tiny difference in how to reset the ESC chip, LAN9252 can be reset by writing over SPI, AX58100 need a pin to go low.
Ax58100 also has a pin for a led that indicates successful read of the eeprom. Pretty useless but has been nice diagnostics when starting up the board.
Other than that one can consider them identical.
I have seen someone state that the AX58100 is faster than the LAN9252. I can not see that, I haven't been in a situation where I can identify the ESC speed as a factor, on individual usec level.
1 year 11 months ago #315499 by pippin88
Replied by pippin88 on topic AX58100
1 year 11 months ago - 1 year 11 months ago #315720 by SOLD
Replied by SOLD on topic AX58100
@Hakan Thanks for creating and sharing, I got the AX58100 working again. It's a very good project to share and learn. I've learned a lot from this project. It's a good starting point to learn how to create and use Ethereum by myself. There are some contents related to STM32 MCU, suitable for those who have no background. It works on VSCode, very beginner-friendly. I will update my board again.
Last edit: 1 year 11 months ago by SOLD.
1 year 11 months ago #315721 by SOLD
This is the AX58100 SPI to STM32F407VGT6 connection test board with Axis and IO expansion board.
I haven't made it into 1PCB yet due to the price constraints of PCB size exceeding 100X100mm.
I'm adding the DAC Op-amp circuit and waiting for the test. Encoder connection.
1 year 11 months ago - 1 year 11 months ago #315722 by SOLD
@ pippin88  Yes, I started with this project to work with STMBL, but I was still a newbie with Ethercat, it was very confusing for me until I discovered Hakan's project that exposed kikad and explained it in detail on YouTube, with immediate response when I had problems via Github.
1 year 11 months ago - 1 year 11 months ago #315723 by SOLD
The asix chips look nice on paper but then again if you pair it with a MCU, how much benefits are there, I don't know? I was just wondering if there are benefits from the programming side so that it would make sense to use that instead of the LAN9252. I have 0 experience with the asix chips so I would love to hear from people that have used both.
Although both maybe available on aliexpress, I would say the LAN9252 is far more obtainable than the asix chips. I typically try to scan something like octoparts for any "special" components I might use, at least if there is even a small chance I make something more than one. A quick look and just digikey and mouser stock these in the thousands. I lost my mind on the chip shortage so now days I try to find multiple sources for parts and if I'm lucky multiple alternatives.
I followed hackaday.io/project/181058-ethercat-serv...e/log/196311-ax58100 for years before the project switched to AX58100. There was a description between the two chips that I didn't quite understand until I found Kahan's project that switched to AX58100 and I followed suit.
Time to create page: 0.154 seconds
