AX58100
1 year 10 months ago #315890 by Hakan
Replied by Hakan on topic AX58100
It is only A and B for counting. You should probably verify with an oscilloscope that the signals from the encoder look like a nice quadrature signal.
The following user(s) said Thank You: SOLD
1 year 10 months ago #315897 by SOLD
Replied by SOLD on topic AX58100
Now I changed the new encoder, it works fine both cw ccw. I use oscilloscope to check ABZ, it's complete.
But I still can't find the index working in Hal.
And another question, the pin name in .comp and the name in pdo are different. Are they related?
1 year 10 months ago #315903 by Hakan
They are related, but not the same. You connect them together in the hal file, using the metalmusings_encoder comp.
Best is to look in the EaserCAT-2000 folder for how it is done there and replicate that, and adapt to your variable naming.
I see these lines in Turner.hal over there
loadrt metalmusings_encoder addf metalmusings-encoder.0     servo-thread net  to_encoder           metalmusings-encoder.0.index-latch-enable lcec.0.6.enc-index-latch-enable net  from_encoder         metalmusings-encoder.0.index-status       lcec.0.6.index-status net  spindle-index-enable metalmusings-encoder.0.index-c-enable
As mentioned before, you compile the module with
halcompile --compile metalmusings_encoder.comp
Uncomment also this line in main.cpp
Encoder1.setLatch(Obj.IndexLatchEnable);
1 year 10 months ago #315904 by COFHAL
Replied by COFHAL on topic AX58100
My encoder now counts correctly, now I have to learn how to use it with LCN.
1 year 10 months ago - 1 year 10 months ago #315929 by SOLD
When you rotate the motor shaft, do you notice any changes in the hal index component?
What additional configurations do you have?
And what is your differential circuit?
Last edit: 1 year 10 months ago by SOLD.
1 year 10 months ago - 1 year 10 months ago #315937 by SOLD
My update encpos is working
- Pin PA0 PA1 PA3 checked with oscillator scope, when no pulse, it is high 5V and low 0V when pulse (test both pull up and pull down)
- Manage Txpdo Rxpdo according to EaserCAT-2000 example
- Improve Hal according to EaserCAT-2000 example
- I tried debugging with Chinese ST-Link, failed
- I monitor with TWINCAT, no change of IndexStatus when motor shaft rotated
I updated STM32 / ESI /EEPROM / XML, but still no change of index
Hal
loadusr -W lcec_conf ethercat-conf.xml loadrt lcec loadrt metalmusings_encoder addf lcec.read-all            servo-thread addf metalmusings-encoder.0     servo-thread addf motion-command-handler   servo-thread addf motion-controller        servo-thread setp lcec.0.1.scale [SPINDLE_9]ENCODER_SCALE #setp lcec.0.1.enc-pos-scale [SPINDLE_9]ENCODER_SCALE net spindle-revs <= lcec.0.1.encpos #net spindle-revs <= lcec.0.1.Encoder Position loadrt invert  loadrt mult2    names=mult2.rps,mult2.rpm addf   invert.0   servo-thread addf   mult2.rps  servo-thread addf   mult2.rpm  servo-thread setp invert.0.in          [SPINDLE_9]ENCODER_SCALE setp mult2.rpm.in0        -60.0 setp mult2.rpm.in0        60.0 net  enc-invert-pos-scale mult2.rps.in0  <= invert.0.out #net  enc-get-freq-rps     mult2.rps.in1  <= lcec.0.1.encfrequency #net  spindle-vel-fb-rps   mult2.rpm.in1  <= mult2.rps.out net  spindle-vel-fb-rpm   mult2.rpm.out #net  spindle-index-enable lcec.0.1.indexstatus net  spindle-vel-fb-rps   mult2.rpm.in1  <= lcec.0.1.encfrequency net  spindle-vel-fb-rpm   mult2.rpm.out net  to_encoder           metalmusings-encoder.0.index-latch-enable lcec.0.1.indexlatchenable net  from_encoder         metalmusings-encoder.0.index-status       lcec.0.1.indexstatus net  spindle-index-enable metalmusings-encoder.0.index-c-enable
main.cpp
///////// Spindle Encoder #include "MyEncoder.h" volatile uint16_t encCnt = 0; void indexPulseEncoderCB1(void); MyEncoder Encoder1(TIM2, PA3, indexPulseEncoderCB1);   void indexPulseEncoderCB1(void) {    encCnt++;    Encoder1.indexPulse(); } ////// EtherCAT routines called regularly, to read data, do stuff and write data void cb_set_outputs(void) // Get Master outputs, slave inputs, first operation {    for (int i = 0; i < min(sizeof(Obj.Outputs), sizeof(OUTPUTS)); i++)       digitalWrite(OUTPUTS[i], Obj.Outputs[i] == 1 ? HIGH : LOW);    analogWrite(DAC1_pin, Obj.Voltage);    Encoder1.setLatch(Obj.IndexLatchEnable);    // Encoder1.setScale(2000);    Step->stepgen_array[0].pos_scale = -Obj.StepsPerMM1; // Scale perhaps changed    Step->stepgen_array[1].pos_scale = -Obj.StepsPerMM2;    Step->stepgen_array[2].pos_scale = -Obj.StepsPerMM3;    Step->stepgen_array[3].pos_scale = -Obj.StepsPerMM4;    posCmd1 = Obj.CommandedPosition1; // The position update    posCmd2 = Obj.CommandedPosition2;    posCmd3 = Obj.CommandedPosition3;    posCmd4 = Obj.CommandedPosition4; } void cb_get_inputs(void) // Set Master inputs, slave outputs, last operation {    Obj.Velocity = Obj.Scale * FrequencyMeasured;    float scale = 1;    if (Obj.Scale != 0.0)       scale = Obj.Scale;    Obj.Velocity = scale * sin(ESCvar.Time * 1e-8 * 6.28); // Test    for (int i = 0; i < min(sizeof(Obj.Inputs), sizeof(INPUTS)); i++)       Obj.Inputs[i] = digitalRead(INPUTS[i]) == HIGH ? 1 : 0; #if 1    Obj.IndexStatus = Encoder1.indexHappened();    Obj.EncPos = Encoder1.currentPos();    Obj.EncFrequency = Encoder1.frequency(longTime.extendTime(micros()));    Obj.IndexByte = Encoder1.getIndexState();    Obj.Velocity = Obj.Scale * FrequencyMeasured; #endif    Obj.ActualPosition1 = Step->stepgen_array[0].pos_fb;    Obj.ActualPosition2 = Step->stepgen_array[1].pos_fb;    Obj.ActualPosition3 = Step->stepgen_array[2].pos_fb;    Obj.ActualPosition4 = Step->stepgen_array[3].pos_fb; }
utypes.c
   /* Inputs */    float Velocity;    uint8_t Inputs[8];    float Frequency;    float ActualPosition1;    float ActualPosition2;    float ActualPosition3;    float ActualPosition4;    float EncPos;    float EncFrequency;    uint16_t DiffT;    uint32_t IndexByte;    uint8_t IndexStatus;    /* Outputs */    float Scale;    uint8_t Outputs[4];    float CommandedPosition1;    float CommandedPosition2;    float CommandedPosition3;    float CommandedPosition4;    int32_t StepsPerMM1;    int32_t StepsPerMM2;    int32_t StepsPerMM3;    int32_t StepsPerMM4;    float Voltage;    uint8_t IndexLatchEnable;
Time to create page: 0.218 seconds
