General Questions about using ethercat
1 year 7 months ago #324360 by Hakan
That xml file is an ESI file. It will not work. See my reply above.
Run "lcec_configgen" and put the output into ethercat-conf.xml.
1 year 7 months ago #324361 by Tntmold
I am way to ignorant on linuxcnc to understand what to do next. They are cia402 drives (Lichuan OL3-E57H) as I have two of them I have started with a lathe config as shown on the first video of this thread. How is the ESI file different from what linuxcnc needs? Should I be using output from pdos as my xml file?
phil@SodickA:~/linuxcnc/configs/sim.axis$ ethercat pdos
=== Master 0, Slave 0 ===
SM0: PhysAddr 0x1000, DefaultSize 128, ControlRegister 0x26, Enable 1
RxPDO 0x1a01 "TxPDO 2"
PDO entry 0x603f:00, 16 bit, "ErrorCode"
PDO entry 0x6041:00, 16 bit, "StatusWord"
PDO entry 0x6064:00, 32 bit, "Position actual value"
PDO entry 0x60fd:00, 32 bit, "Digital inputs"
PDO entry 0x6061:00, 8 bit, "Modes of operation display"
RxPDO 0x1601 "RxPDO 2"
PDO entry 0x6040:00, 16 bit, "ControlWord"
PDO entry 0x6060:00, 8 bit, "Modes of operation"
PDO entry 0x607a:00, 32 bit, "Target position"
PDO entry 0x6081:00, 32 bit, "Profile velocity"
PDO entry 0x6099:01, 32 bit, "Search Switch"
PDO entry 0x6099:02, 32 bit, "Search Zero"
SM1: PhysAddr 0x1100, DefaultSize 128, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1200, DefaultSize 12, ControlRegister 0x64, Enable 1
RxPDO 0x1600 ""
PDO entry 0x6040:00, 16 bit, ""
PDO entry 0x607a:00, 32 bit, ""
PDO entry 0x60ff:00, 32 bit, ""
PDO entry 0x6060:00, 8 bit, ""
PDO entry 0x0000:00, 8 bit, "Gap"
SM3: PhysAddr 0x1300, DefaultSize 19, ControlRegister 0x20, Enable 1
TxPDO 0x1a00 ""
PDO entry 0x6041:00, 16 bit, ""
PDO entry 0x6064:00, 32 bit, ""
PDO entry 0x606c:00, 32 bit, ""
PDO entry 0x6061:00, 8 bit, ""
=== Master 0, Slave 1 ===
RxPDO 0x1600 ""
TxPDO 0x1a00 ""
phil@SodickA:~/linuxcnc/configs/sim.axis$ ethercat sdos
phil@SodickA:~/linuxcnc/configs/sim.axis$ ethercat -v slaves
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000a79
Product code: 0x00002000
Revision number: 0x00000001
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 1139426180 0 0
1 MII up open yes 1 1139427620 1440 720
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x1100/128
Supported protocols: CoE
General:
Group: EtherCAT Driver
Image name:
Order number:
Device name: OL3-E57H
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
DC system time transmission delay: 720 ns
0 MII down closed no 0 - - -
1 MII up open yes - 54668620 2396782160 0
Mailboxes:
General:
Image name:
Order number:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
phil@SodickA:~/linuxcnc/configs/sim.axis$ lcec_configgen
<masters>
<master idx="0">
<slave idx="0" type="generic" vid="0x00000a79" pid="0x00002000" name="D1">
<!--OL3-E57H-->
<syncManager idx="0" dir="out">
<pdo idx="1a01">
<!--TxPDO 2-->
<pdoEntry idx="603f" subIdx="00" bitLen="16" halPin="errorcode" halType="BLANK"/>
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="statusword" halType="BLANK"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="position-actual-value" halType="BLANK"/>
<pdoEntry idx="60fd" subIdx="00" bitLen="32" halPin="digital-inputs" halType="BLANK"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="modes-of-operation-display" halType="BLANK"/>
</pdo>
<pdo idx="1601">
<!--RxPDO 2-->
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="controlword" halType="BLANK"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="modes-of-operation" halType="BLANK"/>
<pdoEntry idx="607a" subIdx="00" bitLen="32" halPin="target-position" halType="BLANK"/>
<pdoEntry idx="6081" subIdx="00" bitLen="32" halPin="profile-velocity" halType="BLANK"/>
<pdoEntry idx="6099" subIdx="01" bitLen="32" halPin="search-switch" halType="BLANK"/>
<pdoEntry idx="6099" subIdx="02" bitLen="32" halPin="search-zero" halType="BLANK"/>
</pdo>
</syncManager>
<syncManager idx="1" dir="out"/>
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="pin-6040-00" halType="BLANK"/>
<pdoEntry idx="607a" subIdx="00" bitLen="32" halPin="pin-607a-00" halType="BLANK"/>
<pdoEntry idx="60ff" subIdx="00" bitLen="32" halPin="pin-60ff-00" halType="BLANK"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="pin-6060-00" halType="BLANK"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1a00">
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="pin-6041-00" halType="BLANK"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="pin-6064-00" halType="BLANK"/>
<pdoEntry idx="606c" subIdx="00" bitLen="32" halPin="pin-606c-00" halType="BLANK"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="pin-6061-00" halType="BLANK"/>
</pdo>
</syncManager>
</slave>
<slave idx="1" type="generic" vid="0x00000a79" pid="0x00002000" name="D2">
<!--OL3-E57H-->
<pdo idx="1a01">
<!--TxPDO 2-->
</pdo>
<pdo idx="1601">
<!--RxPDO 2-->
</pdo>
</syncManager>
<pdo idx="1600">
</pdo>
</syncManager>
<pdo idx="1a00">
</pdo>
</syncManager>
</slave>
</master>
</masters>
1 year 7 months ago - 1 year 7 months ago #324362 by Tntmold
Thanks for your help, I used the output from lcec_configgen and replaced all the BLANK halType entries as S32 or U32, but now I get other errors, am I missing information in the xml file?:
phil@SodickA:~/linuxcnc/configs/sim.axis$ linuxcnc lathe.ini
LINUXCNC - 2.9.3
Machine configuration directory is '/home/phil/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(LIB): /usr/share/linuxcnc/hallib/basic_sim.tcl
setup_kins: cmd=loadrt trivkins coordinates=xz
Found file(REL): ./ethercat.hal
LCEC: Invalid appTimePeriod of 0 for master 0 (should be 1000000).
link (updating variable file): No such file or directory
note: MAXV     max: 3.333 units/sec 200.000 units/min
note: LJOG     max: 3.333 units/sec 200.000 units/min
note: LJOG default: 1.000 units/sec 60.000 units/min
note: jog_order='ZX'
note: jog_invert={'X'}
task: main loop took 0.038776 seconds
task: main loop took 0.019003 seconds
task: 32479 cycles, min=0.000007, max=0.038776, avg=0.001059, 2 latency excursions (> 10x expected cycle time of 0.001000s)
Last edit: 1 year 7 months ago by Tntmold.
1 year 7 months ago #324364 by Hakan
Much better.
In the second line, the "<master idx="0">" line
add so it becomes <master idx="0" appTimePeriod="1000000">
that 1000000 number must match your SERVO_PERIOD setting in the ini file. It is normally 1000000 (= 1 millisecond)
Let's see if that is enough or if you also need to specify distributed clock settings.
1 year 7 months ago #324371 by Tntmold
I still get the shared memory buffers warnings (as before) but linuxcnc will start. The drives show to be in OP status and the linuxcnc shows the axis moving, but the steppers do not move
1 year 7 months ago #324372 by Hakan
I have had the shared memory warning too. I don't think that's related to ethercat, it is something else. I ignored the warning and well it didn't go away but I can't see it causing a problem.
So the drives are in OP, good.
But you use that minimal hal file, the four lines hal file you attached?
You now need to have a hal file describing the movements and limit switches and so on. From a real linuxcnc system.
I guess you have a lathe in mind.
Your drives are cia402 drives, one way is to start from the cia402 example, link here. github.com/dbraun1981/hal-cia402/tree/main/example
You can have a look in the example ethercat-conf.xml for inspiration, but use your own.
The hal file you can use. It's for one axis, you extend it to a Z axis.
Time to create page: 0.269 seconds
