General Questions about using ethercat
1 year 6 months ago - 1 year 6 months ago #327459
by Tntmold
Replied by Tntmold on topic General Questions about using ethercat
I believe I have vid and pid fields correct, output from 'ethercat slaves -v' :
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000a79
Product code: 0x00002000
Revision number: 0x00000001
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 3978170956 0 0
1 MII up open yes 1 3978172356 1400 700
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x1100/128
Supported protocols: CoE
General:
Group: EtherCAT Driver
Image name:
Order number:
Device name: OL3-E57H
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
=== Master 0, Slave 1 ===
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
DC system time transmission delay: 700 ns
0 MII down closed no 0 - - -
1 MII up open yes - 4004182021 2051328265 0
Mailboxes:
General:
Image name:
Order number:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Image name:
Order number:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Image name:
Order number:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Last edit: 1 year 6 months ago by Tntmold.
1 year 6 months ago #327468
by Hakan
Replied by Hakan on topic General Questions about using ethercat
I think you need a dcconf item for every slave in the ethercat-cat.xml file.
I don't have exact syntax here on the phone, but search for dcconf and assignactivate 300 and there should be examples of that line.
1 year 6 months ago #327471
by Tntmold
Thanks, I added dcconf lines (see attachment) but still get the same pin does not exist error
1 year 6 months ago #327482
by Hakan
It's named controlword in ethercat-conf.xml, not cia-controlword.
Also change all lcec.1.0 to lcec.0.1 in the hal file.
1 year 5 months ago #327498
by Tntmold
Thanks, I made those changes and still have the original problem:
SodickA:~/linuxcnc/configs/sim.axis$ linuxcnc lathe.ini
LINUXCNC - 2.9.3
Machine configuration directory is '/home/phil/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(REL): ./ethercat.hal
./ethercat.hal:50: Pin 'lcec.0.0.statusword' does not exist
LinuxCNC terminated with an error. You can find more information in the log:
/home/phil/linuxcnc_debug.txt
and
/home/phil/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Any idea what to try next?
LINUXCNC - 2.9.3
and
1 year 5 months ago #327512
by Hakan
Same principle for the statusword. It is named statusword in ethercat-conf.xml not cia-statusword.
You can go over the names of all pins in ethercat-conf to see that they match the name in the hal file.
Time to create page: 0.190 seconds
