I am unable to get the motors to move, they are open loop steppers. This is my first use of linuxcnc so I don't know much, but I tried power on, then home and got the following:
phil@SodickA:~/linuxcnc/configs/sim.axis$ linuxcnc lathe.ini
LINUXCNC - 2.9.3
Machine configuration directory is '/home/phil/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(REL): ./ethercat.hal
note: MAXV max: 3.333 units/sec 200.000 units/min
note: LJOG max: 3.333 units/sec 200.000 units/min
note: LJOG default: 1.000 units/sec 60.000 units/min
note: jog_order='ZX'
note: jog_invert={'X'}
task: main loop took 0.059970 seconds
task: main loop took 0.075473 seconds
task: main loop took 0.050344 seconds
Can't run a program when not homed
task: main loop took 0.019042 seconds
task: main loop took 0.052011 seconds
joint 0 following error
emc/task/taskintf.cc 976: Error on joint 0, command number 110
task: main loop took 0.036446 seconds
task: main loop took 0.045782 seconds
task: main loop took 0.078341 seconds
task: main loop took 0.050362 seconds
Can't issue MDI command when not homed
task: main loop took 0.018336 seconds
task: 746110 cycles, min=0.000007, max=0.078341, avg=0.001059, 14 latency excursions (> 10x expected cycle time of 0.001000s)
Were can I get a definition of command number 110?
