General Questions about using ethercat
28 Apr 2025 20:15 #327235 by Tntmold
Replied by Tntmold on topic General Questions about using ethercat
That worked but now I get a new error:
./ethercat.hal:50: Pin 'lcec.0.0.cia-statusword' does not exist
this occurs at the following line:
net x-statusword lcec.0.0.cia-statusword => cia402.0.statusword
I clearly have an error here but I don't know where to look to correct the problem
29 Apr 2025 00:42 #327257 by Soccer Kid
Replied by Soccer Kid on topic General Questions about using ethercat
Please check your ethercat.xml file to see if it contains this pin. Similar to...... <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
29 Apr 2025 07:47 #327272 by Hakan
Replied by Hakan on topic General Questions about using ethercat
A common error is to not have the right vid and pid in the ethercat-conf.xml file.
Double-check that the vendor id and product code from the output of
ethercat slaves -p 0 -v
matches the vid and pid fields in ethercat-conf.xml.
Check that for all slaves (0,1,2,etc)
If that didn't help please attach the ethercat-conf.xml file, the hal file and the output of "ethercat slaves -v"
01 May 2025 18:31 #327458 by Tntmold
In the file ethercat.hal I have:
in the file ethercat-conf.xml I have:
<masters>
<master idx="0">
<slave idx="0" type="generic" vid="0x00000a79" pid="0x00002000" name="D1">
<!--OL3-E57H-->
<syncManager idx="0" dir="out">
<pdo idx="1a01">
<!--TxPDO 2-->
<pdoEntry idx="603f" subIdx="00" bitLen="16" halPin="errorcode" halType="BLANK"/>
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="statusword" halType="BLANK"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="position-actual-value" halType="BLANK"/>
<pdoEntry idx="60fd" subIdx="00" bitLen="32" halPin="digital-inputs" halType="BLANK"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="modes-of-operation-display" halType="BLANK"/>
</pdo>
where am I going wrong?
01 May 2025 18:41 - 01 May 2025 18:42 #327459 by Tntmold
I believe I have vid and pid fields correct, output from 'ethercat slaves -v' :
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
  Vendor Id:       0x00000a79
  Product code:    0x00002000
  Revision number: 0x00000001
  Serial number:   0x00000000
DL information:
  FMMU bit operation: no
  Distributed clocks: yes, 64 bit
  DC system time transmission delay: 0 ns
Port  Type  Link  Loop    Signal  NextSlave  RxTime [ns]  Diff [ns]   NextDc [ns]
   0  MII   up    open    yes             -   3978170956           0           0
   1  MII   up    open    yes             1   3978172356        1400         700
   2  N/A   down  closed  no              -            -           -           -
   3  N/A   down  closed  no              -            -           -           -
Mailboxes:
  Bootstrap RX: 0x0000/0, TX: 0x0000/0
  Standard  RX: 0x1000/128, TX: 0x1100/128
  Supported protocols: CoE
General:
  Group: EtherCAT Driver
  Image name:
  Order number:
  Device name: OL3-E57H
  CoE details:
    Enable SDO: yes
    Enable SDO Info: no
    Enable PDO Assign: yes
    Enable PDO Configuration: yes
    Enable Upload at startup: no
    Enable SDO complete access: no
  Flags:
    Enable SafeOp: no
    Enable notLRW: no
  Current consumption: 0 mA
=== Master 0, Slave 1 ===
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
  DC system time transmission delay: 700 ns
   0  MII   down  closed  no              0            -           -           -
   1  MII   up    open    yes             -   4004182021  2051328265           0
Mailboxes:
General:
  Image name:
  Order number:
  CoE details:
    Enable SDO: yes
    Enable SDO Info: no
  Flags:
    Enable SafeOp: no
    Enable notLRW: no
Last edit: 01 May 2025 18:42 by Tntmold.
01 May 2025 21:33 #327468 by Hakan
I think you need a dcconf item for every slave in the ethercat-cat.xml file.
I don't have exact syntax here on the phone, but search for dcconf and assignactivate 300 and there should be examples of that line.
01 May 2025 22:25 #327471 by Tntmold
Thanks, I added dcconf lines (see attachment) but still get the same pin does not exist error
02 May 2025 06:09 #327482 by Hakan
It's named controlword in ethercat-conf.xml, not cia-controlword.
Also change all lcec.1.0 to lcec.0.1 in the hal file.
02 May 2025 13:49 #327498 by Tntmold
Thanks, I made those changes and still have the original problem:
SodickA:~/linuxcnc/configs/sim.axis$ linuxcnc lathe.ini
LINUXCNC - 2.9.3
Machine configuration directory is '/home/phil/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(REL): ./ethercat.hal
./ethercat.hal:50: Pin 'lcec.0.0.statusword' does not exist
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/phil/linuxcnc_debug.txt
and
    /home/phil/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Any idea what to try next?
02 May 2025 16:45 #327512 by Hakan
Same principle for the statusword. It is named statusword in ethercat-conf.xml not cia-statusword.
You can go over the names of all pins in ethercat-conf to see that they match the name in the hal file.
Time to create page: 0.547 seconds
