General Questions about using ethercat
02 Jul 2025 09:42 #331097 by Hakan
Replied by Hakan on topic General Questions about using ethercat
As I said, first make sure the drive is in CIA 402 operation enable mode.
The cia402 component will make the drive go to operation-enable when you set cia402.0.enable true.
There should be a line that looks like this in your hal file
net x-enable <= joint.0.amp-enable-out => cia402.0.enable
If it doesn't go to operation-enable, check cia402.0.stat-op-enable in halshow,
you need to check the statusword and the controlword, and consult the manual
for reasons why the drive doesn't want to go operation enabled.
Time to create page: 0.399 seconds
