Beckhoff Compatibility
1 year 9 months ago #318148 by rodw
Replied by rodw on topic Beckhoff Compatibility
You can drive the VFD directly with RS485 via a USB to RS485 adapter without bothering with Ethercat. Worked perfectly for me.
I think if you wanted to use Ethercat to drive a VFD, you would use a Ethercat compatible VFD.
There is a Omron MX2 driver included. but I have never used it.
1 year 9 months ago #318167 by dschultz
Replied by dschultz on topic Beckhoff Compatibility
Ok, that is what I'm currently using and it works well, I thought maybe it would make more sense to run the VFD through Beckhoff thus all connections to the PC would be EtherCAT. I'll probably continue with USB.
Thanks!
Time to create page: 0.258 seconds
