Missing link in homing LC10E
1 year 9 months ago #317882 by stirra
I have my Lichuan LC10E drive and servo successfully doing internal homing, but I can't figure out how to make the Axis "Home All" button trigger it.  Setting x-home-request signal in halshow generates a homing cycle, but Axis "Home All" causes the motor to just spin quite independently of the drive homing parameters, and never completes.  The x-home-request home cycle completes, and turns on x-homed (cia402.0.stat-homed and joint-0.cia402-homing-finished), but this is also not reflected in Axis.Where does this alternate homing process get linked into Axis?  I have been trying to trace it from halui.home_all but get lost in the bowels of emc.Thanks,-- Ralph
1 year 9 months ago #317890 by rodw
Replied by rodw on topic Missing link in homing LC10E
Just looking at homing.c source and it has a reminder in a comment.
                   // docs: 'If HOME_SEQUENCE is not specified then this joint
                   //        will not be homed by the HOME ALL sequence'
Do you have a home_sequence set for all joints?
1 year 9 months ago #317898 by stirra
Replied by stirra on topic Missing link in homing LC10E
That was "a" problem but not "the" problem. I changed HOME_SEQUENCE to 1 and the behavior remains the same. I commented out all the other HOME_* parameters and still no change. There is still something else I'm missing.
The homecomp.comp file talks about joint._.request-custom-homing as selecting the custom homing process, and the joint.0.request-cia402-homing pin is net'ed to the x-home-request in your cia402_homecomp.comp, but does not get set from Home All, even when HOME_SEQUENCE is positive non-zero.
I tried to attach my files to the last post, but they seem to have vanished.  Here is another attempt.
File Name: cia402_202...2-2.comp
File Size:10.97 KB
File Name: cia402_202...02-2.hal
File Size:2.36 KB
File Name: cia402_202...02-2.ini
File Size:3.79 KB
File Name: cia402_hom...2-2.comp
File Size:16.36 KB
File Name: ethercat-c...02-2.xml
File Size:1.72 KB
1 year 9 months ago #318671 by stirra
After many hours of studying homing.c, cia402.comp, cia402_homecomp.comp and various forum posts, I finally found the last key to making LC10E drive homing work.  Here is my summary of all the changes needed to RodW's example custom homing configuration.  I can now click "Home All" in Axis and have it do a proper mode 6 home.  It still leaves all the axes with "H" in the preview window (rather than the round "survey marker" symbol), but MDI works and everything else seems to function normally.
Changes to get Lichuan LC10E homing working:
1. cia402.comp line 240
      change (statusword >> 10) to (statusword >> 12)
2. ethercat-conf.xml
      add to pdo 1600 section the lines:
           <pdoEntry idx="6098" subIdx="00" bitLen="8"  halPin="home-mode" halType="u32"/>
           <pdoEntry idx="6099" subIdx="01" bitLen="32" halPin="home-hi-speed" halType="u32"/>
           <pdoEntry idx="6099" subIdx="02" bitLen="32" halPin="home-lo-speed" halType="u32"/>
           <pdoEntry idx="609A" subIdx="00" bitLen="32" halPin="home-acc" halType="u32"/>
           <pdoEntry idx="2005" subIdx="24" bitLen="16" halPin="home-timeout" halType="u32"/>
3. cia402.hal
       after loadrt's add lines:
           setp lcec.0.0.home-mode 34
           setp lcec.0.0.home-hi-speed 50000
           setp lcec.0.0.home-lo-speed 50000
           setp lcec.0.0.home-acc 100000
           setp lcec.0.0.home-timeout 5000
      after # homing signals change nets x-home* to:
           net x-home-request joint.0.request-cia402-homing   cia402.0.home joint.0.index-enable
           net x-homing       joint.0.is-cia402-homing       cia402.0.stat-homing
           net x-homed       joint.0.cia402-homing-finished  cia402.0.stat-homed
4. cia402.ini
       in [joint_0] be sure:
           HOME_SEQUENCE = 0 (or whatever sequence number is appropriate)
           HOME_USE_INDEX = YES
           HOME_SEARCH_VEL = 0
           HOME_SEARCH_VEL = 1 (or any non-zero value)
I hope this helps somebody else.
-- Ralph
The following user(s) said Thank You: rodw, COFHAL, onceloved, zmrdko
1 year 9 months ago #318672 by stirra
Forgot to say that the lcec.0.0.home-mode 34 should be changed to the home mode you want. 34 is just handy for testing without external switches connected (34 just returns to index).
1 year 9 months ago #319088 by dschultz
Can this arrangement (servo drive internal homing) be used together with absolute multi-turn encoders on a dual motor gantry?
I'd like to use the multi-turn encoders to get away from home switches if possible...
Time to create page: 0.339 seconds
