- Thank you received: 59
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
1 year 1 month ago #334359
by onceloved
Replied by onceloved on topic Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
关闭eoe试试
1 year 1 month ago #334458
by wankoran
Replied by wankoran on topic Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Thanks, how to turn it off? Forgive me for being a newbie.
1 year 1 month ago #334472
by onceloved
If you are Chinese, add me on QQ: 304394405. If you are foreign, add me on Discord: onceloved.cn
1 year 1 month ago - 1 year 1 month ago #334477
by Hakan
Replied by Hakan on topic Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Afaik you need to re-compile the ethercat sever with the --disable-eoe option.
Last edit: 1 year 1 month ago by Hakan.
1 year 1 month ago #334551
by onceloved
There is another method to extract the sii firmware, modify it and then flash it back. This method is permanent.
1 year 1 month ago #334577
by Hakan
Interesting, does that work reliably?
What do you do, disable EoE mailbox support and also disable EoE?
Wonder why there is a difference between 1.5 and 1.6, EoE seems to be supported also in 1.5.
Time to create page: 0.267 seconds
