Yes , in 2.9.0-pre0 i use ec-debianize.
Now stay test debian 12 with ethercat and have execute step-by step procedure, writed by CORBETT.
Thanks for this.
I have see on debian 12 , but stay again study this problem , the value the all pin the Ethercat drives , they are written late in the associated hal pins, compared to the version I currently use with debian 10 and I can't understand why.
I tried using ethercat version 1.6 and 1.5, but the problem persists.
basically, once linuxcnc is started, the position values of the axes are written in hal after a few seconds and starting from the sequence order of connection of the drives, that is, first the position value of x appears, after 1 second y, after z and so on, after having finished writing all the drives the positions are updated quickly.
Could it be that in the xml file, I configured drives that in reality are not on the machine?
I do this so as to still have all the associated pins in hal and then depending on the machine configuration they work or not equally.
