Long initialization of Ethercat on servo drive SV660N
  • SergeyHM
  • Topic Author
  • New Member
  • New Member
1 year 7 months ago #325455 by SergeyHM
Hi everyoneI have a long initialization of Ethercat on a machine with 7 inovance SV660N servo drivers. I tried different Servoperiods. Sometimes some servo drivers do not initialize - they remain in PreOP. What could be the reason? Maybe someone has encountered this?
LinuxCNC 2.8.4 + ethercat-master 1.6.3
1 year 6 months ago #326861 by Soccer Kid
Perhaps it is related to the EOE mode of the drive. Generally, it is recommended to adopt the drive in COE mode...
1 year 6 months ago - 1 year 6 months ago #326872 by Hakan
I have had long sync times, and there recently was a user that went from debian 10 and igh 1.5 to debian 12, igh 1.6.3 and latest linuxcnc that experienced long time sync times. I switched network adapter which helped a lot, but there was no solution for the other guy.
In the dmesg list, you can see that the client's time is converging, it's just that it's converging too slowly.
One thing you can try, that doesn't solve the root cause, is to restart linuxcnc after such a failed start.
The thinking being that the clients now have a much better starting time for the time sync.
Last edit: 1 year 6 months ago by Hakan.
1 year 5 days ago #337330 by hanz24
I am also trying to use servo from inovance, but I get an error from the configuration of the file where there are some unreadable pins. May I see how your file is configured or maybe there is a reference source that I can use. hope you still open this topic, thanks
1 year 5 days ago #337336 by Hakan
Bring it on, config errors are usually easy to fix.
Error messages, hal file and ethercat-conf.xml are needed.
In general, the ethercat drive pins are created with names from ethercat-conf.xml
Indices are from the id= entry, or if you have names= it takes that first.
1 year 5 days ago #337337 by hanz24
rigth now, the error in my configuration has been resolved, and I can run the LinuxCNC sim using my edited hal/xml. However, my servo drive doesn’t seem to enter OP mode and can’t move the servo motor. I’m confused because there are no errors shown in the terminal, and I’m not sure where to start troubleshooting.
1 year 5 days ago #337338 by Hakan
I assume it is a cia402 drive.
Then the first thing is to try this minimal configuration.
github.com/dbraun1981/hal-cia402/tree/main/example
1 year 5 days ago #337340 by hanz24
i already follow minimal configuration adjust with my servo drive (SV630N), but still the servo doesn't move following linuxcnc sim, and status on my ethercat slave still SAFEOP for my servo drive. here is my hal and xml conf.
1 year 5 days ago #337342 by Hakan
A line was broken in the hal file maybe it is already fixed. Should give an error in the linuxcnc startup window
net x-pos-fb => joint.0.motor-pos-fb <= cia402.0.pos- fb
When it goes to safeop it usually tells why in the syslog.
Show us the last 30 lines or so from the command "sudo dmesg"
1 year 4 days ago #337374 by hanz24
[  130.057958] EtherCAT 0: Link state of ecm0 changed to UP. [  130.098035] EtherCAT 0: 1 slave(s) responding on main device. Re-scanning on next possibility. [  130.098038] EtherCAT 0: Slave states on main device: INIT. [  130.098040] EtherCAT 0: Re-scanning now. [  130.098338] EtherCAT 0: Scanning bus. [  130.423709] EtherCAT 0: Bus scanning completed in 324 ms. [  130.423713] EtherCAT 0: Using slave 0 as DC reference clock. [  130.423716] EtherCAT 0: Starting EoE thread. [  130.429964] EtherCAT 0: Slave states on main device: PREOP. [  223.571989] EtherCAT: Requesting master 0... [  223.571994] EtherCAT: Successfully requested master 0. [  223.572282] EtherCAT 0: Domain0: Logical address 0x00000000, 26 byte, expected working counter 3. [  223.572285] EtherCAT 0:   Datagram domain0-0-main: Logical offset 0x00000000, 26 byte, type LRW. [  223.572300] EtherCAT 0: Master thread exited. [  223.572302] EtherCAT 0: Stopping EoE thread. [  223.572312] EtherCAT 0: EoE thread exited. [  223.572313] EtherCAT 0: Starting EoE thread. [  223.572363] EtherCAT 0: Starting EtherCAT-OP thread. [  223.572393] EtherCAT WARNING 0: 3 datagrams TIMED OUT! [  233.629941] EtherCAT ERROR 0-0: Timeout after 10000 ms while setting state OP. [  233.637940] EtherCAT 0: Slave states on main device: SAFEOP. [  241.597939] EtherCAT 0: Slave states on main device: SAFEOP + ERROR. [  245.322148] EtherCAT 0: Master thread exited. [  245.322152] EtherCAT 0: Stopping EoE thread. [  245.322161] EtherCAT 0: EoE thread exited. [  245.322169] EtherCAT 0: Starting EoE thread. [  245.322206] EtherCAT 0: Starting EtherCAT-IDLE thread. [  245.322267] EtherCAT 0: Releasing master... [  245.322270] EtherCAT 0: Released. [  245.330235] EtherCAT ERROR 0-0: AL status message 0x001B: "Sync manager watchdog". [  245.331449] EtherCAT 0-0: Acknowledged state SAFEOP.
This is some lines that related to ethercat from sudo dmesg, is the problem with sync manager from xml file? or is it because some pdo from my drive didn't match
Time to create page: 0.252 seconds
