xml and hal - I am lost
04 Jun 2025 17:07 #329703 by SwitchWitch
Replied by SwitchWitch on topic xml and hal - I am lost
Sorry - my mistake.
For sure it is a good idea to share the error message.
Now - my problems with the beckhoff modules are solved with the help from 2 friends.
Now I have to get the servos running and to figure out how to configure them.
I will give an update.
04 Jun 2025 18:16 - 04 Jun 2025 18:17 #329710 by Kieran
Replied by Kieran on topic xml and hal - I am lost
Im at about the same step as you. Last night I used the XMLconfiggen to make an xml for the 3 servos i had plugged in at the time. seems reasonable at first glance but might need some edits. My Hal and Ini are based on Hakan's ethercat Rpi video/forum post. getting errors indicating my ini and hal are not up to snuff.
forum.linuxcnc.org/ethercat/42048-notes-...at-on-raspberry-pi-4
Tonight I will bash my head against the keyboard some more and see if I can get a servo to move.
Last edit: 04 Jun 2025 18:17 by Kieran.
04 Jun 2025 18:40 #329711 by Hakan
Replied by Hakan on topic xml and hal - I am lost
Hi guys, the best way is to show so much detail that someone can pinpoint what's wrong.
Starting from lcec_configgen is often a good way for the ethercat-conf.xml
Servos and stepper motors almost always follow the CIA402 standard so there it is best to take the example from github.com/dbraun1981/hal-cia402/tree/main/example and mix that into the config. There are more nuances for drives but lets not go there unless needed.
I and others can help to see what's wrong with your config, you need to attach the errors and outputs from the linuxcnc startup. This output, together with the hal file and ethercat-conf.xml can be attached here.
The following user(s) said Thank You: Kieran
05 Jun 2025 05:15 #329725 by Kieran
Ive got a single X axis going!
I used info from here...    forum.linuxcnc.org/ethercat/54965-stepperonline-a6-servo
My main problem this evening was installing the cia402  hal correctly. I ended up just making a dedicated folder home/linuxcnc/cia402 and placed cia402.comp there.
 Then I opened the terminal and  >>     sudo halcompile --install cia402.comp
that worked!
05 Jun 2025 15:01 #329745 by SwitchWitch
I went the same way but without success. I combined my working files (Beckhoff modules are working as they should) with the ones from MobiusToast. No error on startup but unfortunately no possibility to jog the axis as well. forum.linuxcnc.org/ethercat/54965-steppe...ervo?start=40#329744
05 Jun 2025 15:27 #329749 by Kieran
Hmmm.... so linuxcnc starts with no error, you hit power on (F2?) and servo doesn't come to life? does linuxcnc think its moving when jogging?
05 Jun 2025 15:49 - 05 Jun 2025 17:29 #329752 by SwitchWitch
Yes - I hit power and lcnc thinks it is moving. The servo stays in PreOp.
My mistake - the changed files were not copied into the folders.
Now I have success - I have errors
twopass:pass0: loadusr -W lcec_conf ethercat-conf.xml
twopass: load_the_modules cmd=<orig_loadrt motmod servo_period_nsec=1000000 num_joints=3 base_period_nsec=100000 servo_period_nsec=1000000 num_joints=3 unlock_joints_mask=16 num_dio=6 num_aio=3>
waitpid failed /usr/bin/rtapi_app motmod
/usr/bin/rtapi_app exited without becoming ready
insmod for motmod failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt lcec>
waitpid failed /usr/bin/rtapi_app lcec
insmod for lcec failed, returned -1
Debug file information:
Note: Using POSIX realtime
cia402_homecomp: dlopen: /usr/lib/linuxcnc/modules/cia402_homecomp.so: cannot open shared object file: No such file or directory
<commandline>:0: waitpid failed /usr/bin/rtapi_app cia402_homecomp
<commandline>:0: /usr/bin/rtapi_app exited without becoming ready
<commandline>:0: insmod for cia402_homecomp failed, returned -1
motmod: dlopen: /usr/lib/linuxcnc/modules/motmod.so: undefined symbol: update_joint_homing_params
LinuxCNC Ethercat crashed with signal 11
-- STACK TRACE START
0    /usr/lib/linuxcnc/modules/lcec.so(+0xfc8c) [0x7feb9d9b0c8c]
1    /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7feb9e68a050]
2    /lib/x86_64-linux-gnu/libethercat.so.1(ecrt_slave_config_pdos+0x2f) [0x7feb9d97452f]
3    /usr/lib/linuxcnc/modules/lcec.so(rtapi_app_main+0x40a) [0x7feb9d9b1f38]
4    /usr/bin/rtapi_app(+0x10cd7) [0x55e898f48cd7]
5    /usr/bin/rtapi_app(+0x1162e) [0x55e898f4962e]
6    /usr/bin/rtapi_app(+0x11c2c) [0x55e898f49c2c]
7    /usr/bin/rtapi_app(+0xc974) [0x55e898f44974]
8    /usr/bin/rtapi_app(main+0x70f) [0x55e898f4444f]
9    /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7feb9e67524a]
10    /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7feb9e675305]
11    /usr/bin/rtapi_app(_start+0x21) [0x55e898f44861]
-- STACK TRACE END
Waiting for component 'cia402' to become ready........Waited 3 seconds for master.  giving up.
6457
Stopping realtime threads
Unloading hal components
lcec: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
trivkins: not loaded
tpmod: not loaded
<commandline>:0: unloadrt failed
Mmmhh - in my understanding just the cia402_homecomp.so is missing - could this be right?
Last edit: 05 Jun 2025 17:29 by SwitchWitch.
06 Jun 2025 07:52 #329796 by Hakan
Yes it is missing.
Maybe you already have fixed it by now. It's not a standard component so you need to "halcompile --compile cia402_homecomp.comp" to put the .so file in you config directory.
It's daring to try to get the servo working using a custom setup, I wouldn't do it. I would start with the simplest config possible from dbraun1981 and when that works I would build on with other functions.
But i understand this is part of a complete working setup, so you need to find the cia402_homecomp, compile it and hope for the best.
06 Jun 2025 08:55 - 06 Jun 2025 08:58 #329799 by SwitchWitch
You`re right. When I realized that it is a special customized Version I started everything all over again to go with the simplest version. I did what you proposed and compiled the cia402_homecomp. Than I mixed my working Beckhoff starting point files with the ones from dbraun. Unfortunately it still crashes:
motion.c: Creating unlock hal pins for joint 4
0 /usr/lib/linuxcnc/modules/lcec.so(+0xfc8c) [0x7fc1af3e9c8c]
1 /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7fc1b0303050]
2 /lib/x86_64-linux-gnu/libethercat.so.1(ecrt_slave_config_pdos+0x2f) [0x7fc1af3ad52f]
3 /usr/lib/linuxcnc/modules/lcec.so(rtapi_app_main+0x40a) [0x7fc1af3eaf38]
4 /usr/bin/rtapi_app(+0x10cd7) [0x56167d468cd7]
5 /usr/bin/rtapi_app(+0x1162e) [0x56167d46962e]
6 /usr/bin/rtapi_app(+0x11c2c) [0x56167d469c2c]
7 /usr/bin/rtapi_app(+0xc974) [0x56167d464974]
8 /usr/bin/rtapi_app(main+0x70f) [0x56167d46444f]
9 /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7fc1b02ee24a]
10 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7fc1b02ee305]
11 /usr/bin/rtapi_app(_start+0x21) [0x56167d464861]
-- STACK TRACE END
Waiting for component 'cia402' to become ready.....Waited 3 seconds for master. giving up.
.Note: Using POSIX realtime
2971
lcec: not loaded
motmod: not loaded
homemod: not loaded
tpmod: not loaded
Do you have any Idea what to try next?
Last edit: 06 Jun 2025 08:58 by SwitchWitch.
06 Jun 2025 11:34 #329804 by Hakan
I see you have two slaves with idx="0", that won't work.
List the indexes with "ethercat slaves"
There is another debug option or possibility. The output of "sudo dmesg" show a lot, at the end it may have info that can show the error.
Especially info messages from ethercat master and lcec goes there.
Time to create page: 0.165 seconds
