StepperOnline A6 Servo
26 Feb 2025 13:02 - 26 Feb 2025 13:06 #322692 by Aciera
Replied by Aciera on topic StepperOnline A6 Servo
Can you guys review this and see if you agree?
Yes, that is correct. The idea is that we can set the homing type (ie one of the built in procedures or custom procedure) for each joint.
As described in the manpage:
 This module creates input hal pins joint.n.request-custom-homing that enable an alternate joint homing state machine for requested joints. A hal output pin joint.N.is_custom-homing verifies selection"
linuxcnc.org/docs/devel/html/man/man9/homecomp.9.html
Last edit: 26 Feb 2025 13:06 by Aciera.
The following user(s) said Thank You: TangentAudio, rodw
26 Feb 2025 13:46 #322698 by TangentAudio
Replied by TangentAudio on topic StepperOnline A6 Servo
I'm not surprised I misinterpreted the intent of that pin.  The current state of in-drive homing code and documentation makes it a bit of an "adventure!"
26 Feb 2025 22:26 #322757 by rodw
Replied by rodw on topic StepperOnline A6 Servo
Yes, it is confusing. I tried to use joint.N.is_custom-homing to trigger the cia402 homing input but hal complained about the pin type so had to add a pin of type IO (joint.N.start-homing). I think I could sense homing is done when it is set to zero. But I am getting ahead of myself
28 Feb 2025 20:26 #322886 by MobiusToast
Replied by MobiusToast on topic StepperOnline A6 Servo
I made my own version of the CIA402 and custom home components for the A6 servo and put it on github -> github.com/CollinBardini/linuxcnc-a6-servo
The custom home component writes to a signal called "start-cia-homing" (from Rod's implementation), which kicks off homing in the CIA402 components. The CIA402 component then handles starting homing by writing to controlword and operation mode. While the servo is homing, the home component monitors the statusword until homing is complete.
I made it as barebones as possible to help others get started. I will write a README when I get time. For now, Rod's README is a good starting point.
The following user(s) said Thank You: TangentAudio, rodw, gmr, onceloved, zmrdko, Millimetergott
12 Apr 2025 11:15 - 16 Apr 2025 14:04 #326159 by Millimetergott
Replied by Millimetergott on topic StepperOnline A6 Servo
File Name: Drehmaschine.zip
File Size:34 KB
File Name: Drehmaschi...ckup.zip
File Size:8 KB
File Size:8 KB
Hello, I finally managed to get Linux CNC to start with the HomeComp, but the servos aren't switching to OP mode. I've already tried to find the problem myself, but to no avail. In the folder "Drehmaschine_backup" is my first configuration, with which the motors already worked, but without homing. In the folder "Drehmaschine" is the new configuration with Homecomp.
Last edit: 16 Apr 2025 14:04 by Millimetergott.
05 Jun 2025 14:58 #329744 by SwitchWitch
Replied by SwitchWitch on topic StepperOnline A6 Servo
After having a functional setup for my Beckhoff modules I tried to combine my files withe the ones from MobiusToast to tryout the settings for one of my servos. He mentioned that the files are working for him an that the one axis would at least be moveable.
Surprisingly I have no errors when starting but the servo stays in PreOP and the axis or the motor is doing nothing when jogging the axis.
What could be missing or what could be my mistake(s)?
08 Jun 2025 04:51 #329930 by zmrdko
Replied by zmrdko on topic StepperOnline A6 Servo
if the drive is in PREOP, it would not move. There is some kind of error. It should be described in dmesg
25 Aug 2025 14:07 #333904 by Martin.L
Replied by Martin.L on topic StepperOnline A6 Servo
I throw this here because someone will need it, they removed it from the product page: software stepperonline OMC A6 help.stepperonline.com/en/article/how-to...series-servo-edqavw/
The following user(s) said Thank You: Mallos
22 Nov 2025 13:43 #338973 by bszoke
Replied by bszoke on topic StepperOnline A6 Servo
I made some comments on this in another thread about the PDO configuration, you are correct, internally it does configure the PDO's and sets the PDO assignment register ONLY if you set configPdos="true".
forum.linuxcnc.org/ethercat/56205-help-w...ives?start=20#338949
22 Nov 2025 14:21 #338974 by tommylight
Replied by tommylight on topic StepperOnline A6 Servo
Where should we move the above reply to?
Time to create page: 0.120 seconds
