StepperOnline A6 Servo
10 months 3 weeks ago #339812 by andrax
Replied by andrax on topic StepperOnline A6 Servo
Addendum:
Something is wrong.
In the current configuration of the servos (factory settings), it is not possible to set a speed.
Is anyone else using the 6M60-400H2A1-M17?
10 months 3 weeks ago #339813 by Hakan
Replied by Hakan on topic StepperOnline A6 Servo
Why do you want to set a speed? Normally you set a position.
10 months 3 weeks ago #339816 by andrax
No, I haven't changed anything.
Those are the servo's default settings.
I need to see where I can switch the servo from speed to position mode.
10 months 3 weeks ago - 10 months 3 weeks ago #339817 by Hakan
setp cia402.0.csp-mode 1
sets csp mode.
Last edit: 10 months 3 weeks ago by Hakan.
10 months 3 weeks ago - 10 months 3 weeks ago #339820 by andrax
That won't work.The Slave is currently unavailable in the current configuration.I will have to set it manually.
Last edit: 10 months 3 weeks ago by andrax.
10 months 3 weeks ago #339826 by Hakan
That's how it's done. You really don't tell us much.
Isn't the problem that the slave is not available in the current configuration then?
Time to create page: 0.289 seconds
