Ethercat drives not responding, mesa error finishing read
10 Oct 2025 19:47 #336218 by nanowhat
I can try it, but since ethercat at the command line (linuxcnc isn't even running) shows ~50% lost uploads, what's the point?
I don't think this is a linuxcnc problem, but rather some networking or drive problem.
  • Moderator
  • Moderator
10 Oct 2025 21:50 #336241 by tommylight
sudo apt install wireshark
monitor the network card to see what is going on, look for retransmissions
10 Oct 2025 22:58 #336247 by Hakan
So you built ethercat master from source? Rebuild with the option --disable-eoe or something that makes it exclude eoe.
The three lines you showed from the syslog says it want to establish eoe network interfaces. Disable that.
11 Oct 2025 07:34 - 11 Oct 2025 07:35 #336266 by Hakan
Since you have problems with the Realtek adapters, here is a tip.
Add an Intel PCIe network adapter. Of course you need a free PCIe slot. With an X4 slot you can use a board with multiple interfaces.
And if you only have an M.2 slot you can use that forum.linuxcnc.org/18-computer/55782-adding-a-m-2-ethernet-port
Last edit: 11 Oct 2025 07:35 by Hakan.
12 Oct 2025 11:07 #336318 by rodw
You mentioned you should have an Intel driver. In which case the R8168-dkms won't be installed or do anything. Start at the beginning
what doeslspci | grep -i ethernet
report?
14 Oct 2025 03:38 #336408 by shaying526
I have the same situation as you. If I solve it, I will reply below
26 Nov 2025 22:40 - 26 Nov 2025 22:43 #339271 by nanowhat
Having mostly put the machine together and found ModbusTCP unsuitable, I took another attempt at Ethercat.
  1. I installed LinuxCNC 2.9.4 from the ISO on the nearest available beige box (which has a Realtek ethernet card)
  2. I installed the r8168-dkms driver
  3. I built ethercat from source to exclude EoE as follows:
    1. git clone gitlab.com/etherlab.org/ethercat.git ethercat-master
    2. cd ethercat-master/
    3. git checkout stable-1.6
    4. ./bootstrap (I didn't have autoconf or libtool installed: they are necessary)
    5. ./configure --sysconfdir=/etc/ --disable-8139too --enable-userlib --enable-generic --disable-eoe
    6. make all modules
    7. sudo su
    8. make modules_install install
    9. depmod
    10. exit
    11. sudo nano /etc/ethercat.conf
    12. sudo systemctl enable ethercat.service
    13. sudo systemctl start ethercat.service
    14. sudo systemctl status ethercat.service
    15. sudo chmod 666 /dev/EtherCAT0
    16. sudo nano /etc/udev/rules.d/99-ethercat.rules
    17. sudo udevadm control --reload-rules
  4. I installed linuxcnc-ethercat from the repository
  5. I installed the CIA402 module:
    1. git clone github.com/dbraun1981/hal-cia402
    2. sudo halcompile --install cia402.comp
And it works very nicely most of the time. See attached ethercat xml file.
I see some "PLL error" failures sometimes, which can only be "solved" by restarting the control process. I've tried adjusting refClockSyncCycles and sync0Shift in accordance with some other threads, but I don't understand what those do or what they should actually be.
Last edit: 26 Nov 2025 22:43 by nanowhat.
26 Nov 2025 22:51 #339274 by Hakan
PLL was documented not long ago. Wasn't aware it can stop linuxcnc, that's a bit excessive.
github.com/linuxcnc-ethercat/linuxcnc-et...istributed-clocks.md
27 Nov 2025 02:27 #339281 by nanowhat
The PLL fault doesn't freeze or kill the process: one drive will stop responding to cyclic position commands. The only reset function I've built into my code so far toggles cia402.x.enable and cia402.x.fault-reset, and that doesn't seem to be enough to reestablish communication with the drive.
27 Nov 2025 06:41 - 27 Nov 2025 08:47 #339307 by Hakan
Do you see pll-reset-count increasing?
What's the exact error message you get? I can search the code to see what's going on.
You can always try "ethercat rescan", sometimes it clears errors.
e-stop on when you do this.
Edit: I guess it is PLL error 0x32 error message you get.
Check for other messages in syslog, like missed datagrams.
Improved network latency is the answwer in that case.
Also the pll-reset-count as mentioned above.
Last edit: 27 Nov 2025 08:47 by Hakan.
Time to create page: 0.213 seconds
