Ethercat random jitter fix
- endian
- Thank you received: 134
31 Dec 2025 08:32 #340760
by endian
Replied by endian on topic Ethercat random jitter fix
Posting here with some pictures and any stylization is hell, trust me ...
it looks pretty ... reduction of any jitter in the rt system is more than welcome ... pll is very critical stuff for system and it is nice to see its major improvement
Which driver for network card are you usig for testing it for now? jittering can be produce by generic drivers too i think
I saw it was merged in the master ... we will wait for scott to public new feed or version?
- grandixximo
- Thank you received: 406
31 Dec 2025 16:26 #340781
by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
I use Intel I225 with ec_igc driver, but I also tested generic and seems ok, I plan to do more extensive testing on something worse, just to see how bad I can go before I hit any issue, to have an idea on how cheap a system I can make lol.
The newest PR has not been merged yet at this time, you can get the code from my repo, or wait a few weeks for Scott, he mentioned he was going out of town.
I really think now the code respects the ethercat standard as closely as possible, it might just be a matter of exposing some phasing paramets for picky applications, but visualiziotion with halscope and sync0shift gets you all the way there too, and you have two options to choose from syncToRefClock true or false, if your latency is decent I advise to keep it false, with a refClockSyncCycles of 2, or 10 if you can wait a bit before start moving.
The following user(s) said Thank You: endian
- endian
31 Dec 2025 17:21 - 31 Dec 2025 17:27 #340786
by endian
I have been using negative ref cycles setup ... everything works well, but I have been using native drivers with custom configuration ... latency is very low in my case
it is here ? github.com/grandixximo/linuxcnc-ethercat
Last edit: 31 Dec 2025 17:27 by endian.
- grandixximo
31 Dec 2025 21:01 #340808
by grandixximo
Yes, it is there, unfortunately to test the original code you have to have subpar CPU latency, have some glxgears running, and halscope to simulate/induce bad latency, then you probably have to restart a whole bunch of times, in my case I methodically restarted 100's of times, moved and checked the ferror while moving for the grinding, the better your latency is the less probability you will land on the bad window randomly, by inducing some strong latency on my system running graphical processes which I know give me spikes, I was able to get grinding in the ferror about 20% of the times, without purposely inducing latency I would see it 5% of the times, and I'd really have to look for it with halscope, because opening halscope and plotting the ferror would actually make the latency worse, and the consequently I spotted it more often, without halscope running I could potentially see it only once every 100 restarts if ever, which makes the issue incredibly rare with good latency, the original code was good at syncing, but phasing was random so if you ever were to end up in the grinding window, a restart would have fixed it almost always, phasing was random as far as I tested before my fix.
The following user(s) said Thank You: rodw, NWE
- Thank you received: 4149
01 Jan 2026 02:33 #340820
Replied by rodw on topic Ethercat random jitter fix
This is really awesome work. I would stick to the igc driver which is real time when generic isn't
But from what I am hearing, optimising for system and network latency will probably avoid the issue.
I have a video about that and one user reports he got latency down to about 6 usec following my tutorial.
I suspect by running a latency optimised system has meant I have never experienced this.
The following user(s) said Thank You: endian, NWE
- grandixximo
01 Jan 2026 06:59 #340831
by grandixximo
Yes, if you have good latency it does not really matter how close you are to the sync0shift window, as long as you never jump ahead and back, I also had to force the issue to come up and induce latency in my system by opening graphical intensive applications. But I believe my fix is a real game changer for running ethercat on something that is not super latency optimized, and not see the grinding issue, I hope the community will receive it well, I'm here for any bug fixes or whatnot...
The following user(s) said Thank You: rodw, endian
- TAKUYA
07 Mar 2026 20:33 #344002
by TAKUYA
Replied by TAKUYA on topic Ethercat random jitter fix
Great work so far.
I am just not sure i fully understand it all yet.
Does that mean that with the installed PR from end of 2025, SyncToRefClock=True fixes it all? Or is the currently open PR still needed?
Thanks!
Thanks!
- andrax
- Thank you received: 83
08 Mar 2026 12:58 #344020
by andrax
Replied by andrax on topic Ethercat random jitter fix
I also need to ask about this.
How does the jitter problem manifest itself?
Can I see it in the dmesg output?
I have tried to read up on the topic on GitHub, but I still don't understand the actual problem.
It's also a translation problem.
Another question: is this patch already implemented in the current linuxcnc release, or does it have to be installed manually?
Is there any documentation on the additional commands, where and how they are called?
andrax
andrax
- Hakan
- Thank you received: 454
08 Mar 2026 13:33 #344022
by Hakan
Replied by Hakan on topic Ethercat random jitter fix
It sounds like you get gravel in the servo motors from time to time.
Or you get click sounds from the motors. It repeats itself with a few or many minutes apart.
The first thing to do is to enable syncToRefClock and enable DC mode for the servos,
this will keep the servo loop in sync with the DC.
What grandixximo is doing here is fixing an effect that despite DC and servo loop are synchronized,
the two loops have been started with an undetermined/unfortunate phase between them.
The gravel sound is there all the time and it doesn't go away until linuxcnc is restarted.
Surprisingly, yesterday Sasha Ittner popped up in the PR log and mentioned he had been working
on a complete redesign of the DC system, eliminating all these problems (don't know details)
grandixximo seems to have reviewed that work and decided to adopt Sasha's work.
grandixximo will have to say himself. And if you don't know, Sasha Ittner is the author of linuxcnc-ethercat
from many (>10) years ago.
- andrax
08 Mar 2026 14:06 #344025
by andrax
Okay, thank you.
I had already thought that the issue had something to do with packet loss when starting LinuxCNC.
However, this seems to occur during operation, which I have not yet experienced. If this work results in ethercat running more stably, I will simply wait until Sascha announces an official patch, which will likely be available via update.
Until then, I will simply stick with refClockSyncCycles="1">.
Time to create page: 0.250 seconds
