Ethercat random jitter fix
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Dec 2025 01:37 - 25 Dec 2025 06:44 #340487 by grandixximo
Ethercat random jitter fix was created by grandixximo
If you have been using linuxcnc ethercat, you almost certainly have experienced jitter, the motor makes a weird noise, restarting lxcnc once or twice, and it works well, no amount of latency improvements ever fix this completly, just happens a bit less often.
Since I had sometime to kill this Christmas I put a lot of effort into pin pointing the cause of this issue, and fix it for good, I will share the code in the next few days, still doing some testing and refinements, but I wanted to share what I am at this time practically certain the cause was/is.
The issue is the servo thread syncs with the DC clock, but it is not in phase, each time linuxcnc starts the app-phase is randomly out of phase with the DC epoch time (Fixes value of "DC reference time" displayed by ethercat master), the fix was to remove app-phase from DC epoch, and drift the servo-thread to align with this time, that's all, this will make sure your packets are sent (with jitter) in phase with the DC epoch, and your sync0shift will actually allow for your jitter/latency.
I will do some more testing refine the code, and soon share the fix with the linuxcnc community,
Merry Christmas and Happy Holidays to all!
Last edit: 25 Dec 2025 06:44 by grandixximo.
The following user(s) said Thank You: maxi177, onceloved, NWE
25 Dec 2025 02:48 #340488 by Hakan
Replied by Hakan on topic Found the main source of the jitter
Indeed, it is the servoloop that isn't in sync with the dc clock.
github.com/linuxcnc-ethercat/linuxcnc-et...s.md#master-settings
  • grandixximo
  • Platinum Member
  • Platinum Member
25 Dec 2025 03:46 - 25 Dec 2025 04:08 #340491 by grandixximo
Replied by grandixximo on topic Found the main source of the jitter
I have used your syncToRefClock "true" option, the random jitter issue persisted. The issue is not just sync, it is also phase, by simply drifting to match the DC epoch, you can get in phase. Only after the fix I am NOW finally able to create the jitter at WILL by setting a sync0shift of 10~30us this is expected, as preempt_rt has 20-60us jitter, if you move the sync0shift window in the jitter you should get jitter, this was not the case with just syncToRefClock "true" the servo was in sync, but the phasing was random. I will further test tomorrow, but this is something that has escaped the community for a while.
Sync is also important, but phasing was completely overlooked, I think the current code assumes phase alignment happens automatically, this might be because of ethercat's docs not explaining this well, or because of how linuxcnc is structured the servo thread is started completely separate from the lcec, the servo thread phasing has to be done manually to match DC epoch, even if DC epoch was written by lcec, the moment when servo-thread addf's lcec is practically random, the phasing will be random. Not sure if you understand, I am very deep into testing this for days now, and I can assure you, I have it fixed now, but it was not before.
Last edit: 25 Dec 2025 04:08 by grandixximo.
25 Dec 2025 13:19 #340502 by Hakan
I can only take credit for rediscovering the PLL code and write some lines of documentation.
Sasha Ittner made the PLL code back in 2018 and it hasn't changed since then.
Will be interesting to see what you come up with.
The following user(s) said Thank You: grandixximo
25 Dec 2025 14:28 #340505 by endian
Replied by endian on topic Found the main source of the jitter
i am here just for subscribe and learn something more about PLL ...
  • grandixximo
  • Platinum Member
  • Platinum Member
27 Dec 2025 09:44 #340584 by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
github.com/linuxcnc-ethercat/linuxcnc-et...631ab668516b649fcaaf
Posted the PR
Will be happy to get some feedback, thanks
The following user(s) said Thank You: endian, onceloved, NWE
  • grandixximo
  • Platinum Member
  • Platinum Member
29 Dec 2025 15:48 #340684 by grandixximo
The PR has been merged to linuxcnc-ethercat I have some testing modifications which I have not been able to test yet, will update here after I test myself, might be another PR before everything is proper.
29 Dec 2025 15:55 #340687 by endian
Replied by endian on topic Ethercat random jitter fix
If you will test it .. please share some visual results before and after{for example scope printscreen) .. We are all interested in your pr I think !
thanks
  • grandixximo
  • Platinum Member
  • Platinum Member
30 Dec 2025 02:30 - 30 Dec 2025 07:42 #340704 by grandixximo
The new PR is up, this fixes everything, i will post some pictures later
Edit:
Still got a few kinks to iron out, probably tomorrow for finalized PR
Last edit: 30 Dec 2025 07:42 by grandixximo.
  • grandixximo
  • Platinum Member
  • Platinum Member
31 Dec 2025 01:44 - 31 Dec 2025 01:45 #340758 by grandixximo
github.com/linuxcnc-ethercat/linuxcnc-ethercat/pull/465
new PR with pictures, which I don't want to repost here, look at explanation on github, I'm available for questions. code has been tested, everything should be way better now, and possibly can even use not so good hardware and achieve decent ethercat no grinding.
Last edit: 31 Dec 2025 01:45 by grandixximo.
The following user(s) said Thank You: rodw, endian
Time to create page: 0.130 seconds
