Stepperonline Y series/ YAKO YKD2608PE configuration
8 months 3 weeks ago - 8 months 3 weeks ago #342500 by Hakan
There it is.
The problem is with your slave 5, the EL1014.
Can it be that it is a very old version? They had a different PDO mapping.
Can you temporarily remove or comment out slave idx=5 and see if you
come any further?
We can come back to how to fix it for the EL1014.
Well, it is to run lcec_configgen with the option, "lcec_configgen --typedb=false"
and then take the info for slave 5 from that output.
Last edit: 8 months 3 weeks ago by Hakan.
The following user(s) said Thank You: IndeeSales
8 months 3 weeks ago #342506 by tommylight
yes I dont know what keeps happening I have registered 3 times in 72hrs.
Yes, i have noticed that, hence my question, but i think you should be clear from now on, based on what i gather this happens when there is a single post from a member in a certain timeframe and might be due to automation set to disable spammer accounts.
8 months 3 weeks ago #342509 by IndeeSales
Okay so i commented out the 2 1014's then 2 2004 now i get a servo thread not found so i attached all files and the log again
File Name: ethercat-c...2-05.xml
File Size:5.05 KB
File Name: linuxcnc_2...2-05.txt
File Size:5.26 KB
File Name: Ethercat_2...2-05.hal
File Size:5.38 KB
8 months 3 weeks ago #342511 by Hakan
Progress!
You forgot the two first lines from that example cia402.hal
loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
8 months 3 weeks ago #342541 by IndeeSales
Okay seems we have progress!!! I changed those I/O modules to newer ones and they are working renumbered and structured the xml file to reflect that now my error shows
./Ethercat.hal:51: Pin 'lcec.0.3.cia-statusword' does not exist
10890
is there a place I missed to add these?
8 months 3 weeks ago #342544 by Hakan
You just named them "statusword" instead of "cia-statusword" in the ethercat-conf.xml file.
It is often worthwhile to examine the words it complains about.
Time to create page: 0.059 seconds
