Flexible GUI
2 years 5 months ago #300041 by JT
Replied by JT on topic Flexible GUI
I've made a lot of improvements to Flex GUI in the last few weeks and with some help you can create a button, checkbutton, checkbox or radio button that controls a hal out pin. I've got almost all status labels that return a float have the precision set to 3 for metric and 4 for inch and if you specify the precision in a Dynamic Property then Flex uses that instead of the default.
JT
2 years 4 months ago - 2 years 4 months ago #303006 by JT
Flex GUI is up to version 0.8.0 and includes MDI buttons now.
Flex GUI is for folks that want just what they want in a GUI, no more no less.
JT
Last edit: 2 years 4 months ago by JT.
The following user(s) said Thank You: tommylight, Grotius, Aciera
2 years 4 months ago #303018 by Grotius
Replied by Grotius on topic Flexible GUI
@JT,
In a few post earlyer you mentioned:
Qt Creator is for C++ and Qt Designer is for python.
The qt designer creates .ui files that can be used with qt creator.
The link is broken:
gnipsel.com/linuxcnc/flex/index.html
Made a new link for you:
gnipsel.com/linuxcnc/flexgui/index.html
github link
I want to say, i really like your work. A few years ago when i started linuxcnc,
i followed your gtk course gnipsel.com/glade/index.html .
I think you can also do widget overlay in the gremlin screen these days to show dro's. image missing /media/kunena/emoticons/cool.png
2 years 4 months ago - 2 years 4 months ago #303023 by JT
I updated the links in the first posts.
Now if I can figure out how to code a plotter Flex GUI will be complete.
JT
2 years 4 months ago #303042 by Grotius
@JT,
Do you want to code a new plotter or what are your ingredients?
2 years 4 months ago #303043 by JT
@JT,
I need to get a plotter to work with PyQt6. I would like to use OpenGL with the QOpenGLWidget. If possible use LinuxCNC libraries to parse the G code. How Flex GUI works is if a widget is found then the code is attached to it so in the case of a plotter if a container with an object name of plot_widget is found then the plotter is inserted into the plot_widget container. Any help is much appreciated.
JT
Moderators: JT
