Flexible GUI
2 years 3 months ago - 2 years 3 months ago #306293 by MennilTossFlykune
Replied by MennilTossFlykune on topic Flexible GUI
In the plot widget, to automatically reload a file when an offset has changed you could maybe use the fingerprint
For example:
        fingerprint = (self.logger.npts,         self.soft_limits(),         s.actual_position,         s.motion_mode,         s.current_vel,         s.joint_actual_position,         s.homed,         s.limit,             s.tool_in_spindle,                      s.g5x_offset,         s.g92_offset,         s.rotation_xy,         s.tool_offset)         if fingerprint[9:12] != self.fingerprint[9:12] or s.file != self._current_file:             if self.display_loaded:                 self.load()         if fingerprint != self.fingerprint:             self.fingerprint = fingerprint                         self.update()
files.catbox.moe/5km48d.mp4
Last edit: 2 years 3 months ago by MennilTossFlykune. Reason: couldn't embed video
The following user(s) said Thank You: blazini36, JT
2 years 3 months ago - 2 years 3 months ago #306330 by JT
Replied by JT on topic Flexible GUI
For example:
Can you share the whole code for what I saw in the video? For some reason the plot is not moving when I set an offset. The xyz origin marker is the only thing that moves...
JT
Last edit: 2 years 3 months ago by JT.
2 years 3 months ago #306356 by blazini36
Replied by blazini36 on topic Flexible GUI
For example:
        fingerprint = (self.logger.npts,         self.soft_limits(),         s.actual_position,         s.motion_mode,         s.current_vel,         s.joint_actual_position,         s.homed,         s.limit,             s.tool_in_spindle,                      s.g5x_offset,         s.g92_offset,         s.rotation_xy,         s.tool_offset)         if fingerprint[9:12] != self.fingerprint[9:12] or s.file != self._current_file:             if self.display_loaded:                 self.load()         if fingerprint != self.fingerprint:             self.fingerprint = fingerprint                         self.update() https://files.catbox.moe/5km48d.mp4
Any chance you can share the whole configuration you have shown in your post a couple pages back? That looks pretty good. I've been pecking at a Flex UI for a bit but haven't gotten very far yet.
2 years 3 months ago #306367 by JT
Ok, I did figure out that I can't test the plotter with a sim running. Everything works as it should when I run from installed.
I still would like to look at your code if possible.
JT
2 years 3 months ago - 2 years 3 months ago #306370 by MennilTossFlykune
I wanted to be able to test it in qtdragon so it's PyQt5 instead
This one does work as a standalone window
Last edit: 2 years 3 months ago by MennilTossFlykune. Reason: attached wrong file
2 years 3 months ago #306451 by MennilTossFlykune
I don't think I have it anymore. It was based on Persei8's QtDragon version but when the plotter stuff is all working I'll modify the standard QtDragon UI instead.
Moderators: JT
Time to create page: 0.296 seconds
