Flexible GUI
2 years 8 months ago #292661 by JT
Replied by JT on topic Flexible GUI
I'd think you can just have the Python handler create a component and export hal pins straight out of Python right?
I think this is a really good idea for most of us who can wire up just about anything but draw a blank stare at anything that doesn't end in .hal or .ini
Thanks to Chris helping me figure out why the HAL pins were not showing up I'll have HAL pins connected to widgets by tomorrow!
The idea is you create a button for example with a few dynamic properties and the code "discovers" them and makes the pins and connects the button to HAL.
I'm thinking at this point having at least the following dynamic properties (you add them by clicking on the green plus sign in Property Editor for the object and adding a string property.
Name     Property function hal pin_1      name, type, direction pin_2       input, hal_bit, hal_in
JT
2 years 8 months ago - 2 years 8 months ago #292739 by JT
Got the MDI button code working.
You may notice the DRO pausing while running the MDI command and that has been fixed.
JT
Last edit: 2 years 8 months ago by JT.
2 years 8 months ago #292756 by blazini36
Replied by blazini36 on topic Flexible GUI
What is the "Plot" tab? is that supposed to be Gremlin? Didn't seem to show anything when I ran the example.
2 years 8 months ago #292761 by JT
No it's not gremlin, it's a brand new plotter based on PyQt6 and OpenGL... just not done yet. Everything in Flex GUI is based on the latest tools so it will last a long time I hope.
JT
2 years 8 months ago - 2 years 8 months ago #292766 by JT
Keep in your mind that I just started working on this a couple of weeks ago and only work on it for about an hour each morning while having my coffee... and it's you that pointed me to the HAL pins so I'm going to finish that up first.
JT
The following user(s) said Thank You: MennilTossFlykune, eMTea
2 years 7 months ago #294999 by blazini36
Still haven't gotten around to really diving into this yet, but once I get the firmware sorted out on my new controll panel I'm gonna see what this can do.
Moderators: JT
Time to create page: 0.402 seconds
